When I try to start my 6.0 in cooler temps even though it may be 55 degrees if it starts it runs very rough.But if plug the block heater in it will start right up and usually run quite well. I am at a loss I tested the FICM in the past but have not checked it lately. Wondering what to do at this point. Thanks for your time.. Harry
Not to change subject, but i have a 06 f-250 with block heater with no wire harness. Question is where can i purchase one, will be travel up to northen new york..thank u ...jim
Your local dealer should have one. Or check out eBay they normally have some.
Harry Your Best bet is to Find a gauge setup you like that Plugs into the OBDII Port
You can then test what these guys are telling you to test
You may find some things that you didn't expect then you will be Ahead the GAME
These trucks are Cheap to fix if you are AHEAD the GAME
FALL Behind the GAME and you may PAY Dearly
Benny I have the Scan Gauge II and have no codes that are showing I am afraid I do not know how to find 'soft' codes. But evrything that I have found seems to indicate FICM trouble but whether it is or not, I called Ed today and ordered a new one with an ECO tune as blue spring fuel pressure kit. Gonna find out for sure one way or another. LOL Thanks so much for all your help. Harry
Benny I finally got a code while driving tonight the truck was very sluggish then I got a CEL and code PO 264
