Engine tune up to do's?
Old Jun 23, 2003 | 05:59 PM
steve81's Avatar
steve81
Ok, this is going to sound like a really dumb question to most of you but I'm a new ford owner and not sure what to do. Short of changing the oil, spark plugs, wires, distributor and flushing the coolant system, what else can I do to tune my old 460 up and get her running better? She runs good right now, I'd just like to make it run a little better.
Thanks,
Steve
Old Jun 23, 2003 | 07:11 PM
archangel's Avatar
archangel
Check the freeze plugs for corrosion and change the thermostat for insurance if its 10 years old or more.
Check all the coolant hoses as oil will make them soft and prone to blowing.
Assuming it's carbureted, not fuel injected, and the fuel hoses look old enough that they might be original, change them as when they added MTBE it hardened them and they might/will start leaking when you are the furthest from someplace they will have a replacement available, also that 10 gallons will now only get you 15 miles, and the nearest gas station will be 35 miles away.
OH, and it seems that NOBODY EVER changes the brake fluid as it sucks moisture out of the air and will rust out the wheel cylinders and might cause you to lose your brakes if it gets hot enough to turn that H2O into water vapor.
Old Jun 23, 2003 | 09:38 PM
mustange70's Avatar
mustange70
Also the aircleaner, fuel filte (if it has a filter on the carb you should put an inline filter for insurance) battery cables (maybe the battery if its old and there acid showing its face, maybe a new high flow muffler. Other than that you have everything covered.
Old Jun 24, 2003 | 01:24 AM
archangel's Avatar
archangel
Heck, if you instaled a high flow muffler, why not go with a set of headers and a bigger exhaust system.
But then you might as well install a better manafold and carb, but don't forget to select the correct cam to make it all come together.
Old Jun 24, 2003 | 01:33 AM
Omen's Avatar
Omen
Change fluids in diff, tranny. Lube the chassis. Repack and lube all bearings. Balance and rotate tires. Change out the brakes. New belts. Ruff up the pullies with an emory cloth. Did I spell emory right? These are just a few things you can do. I know breaks don't make it run better but you gotta stop some time.
Chassis lube and bearing repacks with make it ride smoother. New fluids in diff and tranny will help with power transfer and keep all moving parts cool and lubed up.
Old Jun 24, 2003 | 09:39 AM
NAPAMan's Avatar
NAPAMan
I believe that you are all overlooking some very important things, such as: pcv valve, and the crank case breather, now if it's fuel injected I would seriously be testing or just flat out changing the Oxygen sensor, as this can effect gas milege, idle quality, smoking, and throttle response. Another thing although it might not make it run better is flushing your cooling system, and adding a good fuel system cleaner to the gas.
Also get a K&N air filter for it, as it will lead to better mpg, and throttle response.
Old Jun 24, 2003 | 11:29 AM
steve83's Avatar
steve83
Get the Haynes manual and read Ch. 1.
Old Jun 25, 2003 | 09:20 AM
NAPAMan's Avatar
NAPAMan
LOL Good idea!~
