oil pan rust
Old Nov 26, 2013 | 08:06 PM
lght1's Avatar
lght1
Question oil pan rust
hi
another day another issue.
the oil pan from my dusted texas engine is pristine, while my drop in with great compression isn't...well completely great. (mid atlantic states..e series donor)
can the oil pan from my texas dusted be removed without damaging the lip/sealing surface?
i have heard that it is almost impossible to do this without damaging the pan.
Old Nov 26, 2013 | 08:53 PM
crop harvester's Avatar
crop harvester
get a quality putty knife and tap it through the silicone rubber to break the bond,the blade will need to be thicker than your typical off the shelf unit.
Old Nov 26, 2013 | 10:03 PM
scotttahoe's Avatar
scotttahoe
I'm pretty sure you have to remove the motor to remove the pan and turn it upside down to put on new RTV if you get any oil on the RTV it will not work and will have continuous leaks.
Old Nov 26, 2013 | 10:05 PM
lght1's Avatar
lght1
hi
the donor engine isn't in yet and the dusted engine is coming out.
Old Nov 26, 2013 | 10:25 PM
scotttahoe's Avatar
scotttahoe
That's right. Will be easy then and will look real nice.
Old Dec 1, 2013 | 12:32 AM
73f250cummins's Avatar
73f250cummins
I am sanding mine down with sand paper and being super cautious and then putting fiber glass over the bottom the best I can. Heard and read It works pretty good.
Old Dec 1, 2013 | 06:07 AM
Mowing Man's Avatar
Mowing Man
Just remember to use some good Loctite and a new o ring on the dipstick tube nut. Otherwise it will haunt you....
ford1183
Nov 28, 2012 04:52 PM
szotty
18
Oct 23, 2010 11:23 AM
kawa
Jul 19, 2009 11:33 PM
kupiec20
May 18, 2008 10:10 PM
