Fixing Broken Tail pipe
Old Nov 24, 2013 | 07:00 PM
L_C35P's Avatar
L_C35P
The tail pipe on my 1994 F150 broke off right where it meets the muffler and was wondering if I could do a temporary fix by brazing it with a plumber's propane torch and some silver solder . The solder's melting point is about 425F. Is this going to hold up until I get enough money saved to fix/replace it properly?How long do you think this fix will last? If not what other ideas do you recommend?Or does anyone know how much a shop would charge to weld it? and how far would the truck be able to drive like this? I'm asking the last question because I live in a rural community and the closest shop would be about 50km drive unless I can find someone in town to weld it for me. Thanks.
Old Nov 24, 2013 | 09:26 PM
rla2005's Avatar
rla2005
You'll never generate enough heat to melt that solder with a propane torch, never mind the fact the joint would have to be super clean and a bunch of flux for it to stick.
Every shop and area has dramatically different prices, call a few shops for a general ballpark figure.
Old Nov 24, 2013 | 10:01 PM
Jarryd's Avatar
Jarryd
How bad is the break? I've never paid more than $30 to have a muffler welded up, actually that was for a pair on my mustang. I'd just get it fixed. You don't really need a tail pipe though, mine is dumped after the muffler.
Old Nov 24, 2013 | 10:27 PM
L_C35P's Avatar
L_C35P
It's broken right off and for $30 that's not bad at all I've been wanting to get the whole system changed back to the original system as the previous owner did a backyard job but I can't afford it at this point in time although it would be the perfect opportunity. So you guys don't recommend the silver braze then...? Thanks
Old Nov 24, 2013 | 10:29 PM
Jarryd's Avatar
Jarryd
I'd rather do it right the first time.
dpayne7571
Mar 30, 2019 07:47 AM
hedhntr
Dec 12, 2012 06:12 AM
feeniks4.9
Exhaust Systems
Oct 21, 2010 09:05 PM
Shade
Jun 27, 2008 07:35 AM
polar800
2004 - 2008 F150
Apr 24, 2004 09:19 PM
