up pipe flaring????
Old Dec 11, 2012 | 10:13 PM
hedhntr's Avatar
hedhntr
up pipe flaring????
somewhere i have seen where people are taking there uppipes to a muffler shop and having the ends flared so the donughts are tight. wanting to do this soon and cant remember exactly what to tell the muffler shop. anyone know or has anyone done this?
Old Dec 11, 2012 | 10:18 PM
glovemeister's Avatar
glovemeister
I don't know if I would waste my time with it. Really is a better idea to cry once and get bellowed up-pipes.
Old Dec 11, 2012 | 10:30 PM
Ford4Life7.3's Avatar
Ford4Life7.3
Or if you can fab, make your own like Bill. oooohh Biiilllllllll? Care to chime in haha?
Old Dec 11, 2012 | 10:43 PM
hedhntr's Avatar
hedhntr
im also seeing some people say u have to drop the trans and others say no way.
Old Dec 11, 2012 | 11:18 PM
glovemeister
Honestly it is better to drop it. Other than that you can remove the turbo.
Old Dec 12, 2012 | 12:11 AM
ReBilld's Avatar
ReBilld
I don't know if I would try to flare the pipes or not. If they have been leaking and are grooved on the ends, they may split when you try to flare them. If you fab a set of bellowed pipes, you will have to drop the trans.
Old Dec 12, 2012 | 06:12 AM
JCart's Avatar
JCart
What I've done with my trucks is this:
Put a large diameter section of solid rod or heavy wall pipe in a vise to use as an anvil. Next slide the up pipe over the anvil and with hammer reshape the up pipe. Using a felt marker, mark a line around the circumference of the up pipe and as you reshape the pipe the marker will be remove and will aid in shaping uniformity. Keep your doughnut handy to test fit it as it should fit snuggly when done. Don't hit too hard, just enough to reshape and remove any abrasion caused by the doughnuts. Once your happy with the snug fit coat with high temp anti-seize paste. Other thing I did was grind off (best to do at machine shop), I used calipers and grinder.... Some face material on the doughnut clamp (thickness) so it can bolt tighter to the doughnut/collector interface. Remember to coat everything, bolts, doughnuts etc with high temp anti-seize paste.
jrc
dpayne7571
Mar 30, 2019 07:47 AM
TNT in Round Rock
62
Jul 22, 2017 05:21 PM
Shade
Jun 27, 2008 07:35 AM
whitetr
13
May 14, 2007 05:02 AM
polar800
2004 - 2008 F150
Apr 24, 2004 09:19 PM
