Oiling a vehicle
Old Jun 23, 2003 | 11:09 AM
68torino's Avatar
68torino
Oiling a vehicle
Just a curiousity question. Seen a post someplace else that mentioned oiling a vehicle to prevent rust. This came out of a Canadian post. Now I'm familar with undercoating, rustproofing sprays, rock guard and spray in liners. But what would you use for oiling the underside? Linseed oil?
Old Jun 23, 2003 | 11:43 AM
TallPaul's Avatar
TallPaul
Oiling a vehicle
The army uses a "rust inhibitor" fluid, which they say to either wipe or spray on every eight months. They say it "slows the spread of new rust and cleans up old rust ... [and it] works by eliminating moisture that holds salt, dirt, and other pollutants that eat up metal. It also lubes moving parts and penetrates existing rust." They say it takes about 3 gallons to treat a 2.5- or 5- ton truck. (I'm getting this info from the Army's "Preventive Maintenance Monthly" of May 2003.) Whatever the Army is using, it sounds like it is similar to WD-40 or maybe the Army surplus store would have some of the official stuff.
Old Jun 24, 2003 | 10:52 AM
68torino's Avatar
68torino
Oiling a vehicle
Thanks TallPaul, I'm always looking for an easy method to slow rust. I'll check in Sioux Falls see if I can find any. Think I'll look on some mil. sites see what I can find.
Old Jun 24, 2003 | 11:37 AM
jimmyk57's Avatar
jimmyk57
Oiling a vehicle
All I use on my vehicles is the cheapest 10W30 I can find. Never use used oil, there's crap in it that will cause problems with rubber components. I tried using hydralic oil once becaue I was told it would creep into all the little areas, but found it "evaporated" away too quickly. Mine get sprayed twice a year, and it sure keeps things from rusting!
Old Jun 24, 2003 | 12:09 PM
Huntsman's Avatar
Huntsman
Oiling a vehicle
I have also read (probably at FTE) of people pouring oil into cab corners and inside doors to prevent rust.
Old Jun 25, 2003 | 11:54 AM
68torino's Avatar
68torino
Oiling a vehicle
Now that does open up possibilities, actually never thought of different uses for cheap oils. Although since I don't have a garage I store my containers of used oil in the back of my son's pickup, which would explain it not rusting anymore. If I find a good oil to use this could help with fastners not rusting stuck.
Hmmm now to run some specs and make a choice.
Old Jun 25, 2003 | 11:25 PM
Ironbelly's Avatar
Ironbelly
Oiling a vehicle
I've done that, also fender corners and other hard to reach places. Rather wipe away a little excess oil now and then than have rust.
eldorado73
Jan 26, 2014 08:25 AM
jbrianas
Jan 1, 2013 07:37 PM
Bill in Bama
20
Jan 16, 2011 02:32 PM
95250mac
Oil & Lubrication
Sep 25, 2006 12:23 AM
PostalDave
1983 - 2012 Ranger & B-Series
Oct 14, 2002 03:06 PM
