advise please!
Old Dec 6, 2013 | 06:51 PM
  #91
427 fordman's Avatar
427 fordman
Sounds good Glenn! Are you done then?
Old Dec 6, 2013 | 07:03 PM
  #92
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Question
Originally Posted by oldbird1965
My DP is in with maybe a 1/4 to 3/8's of a inch clearance on both sides. It was a challenge to get this without denting the DP in. When I first started last winter I cut the pinch weld in four places with the sawzall and flattened them down. Today I pryed up the middle part of the pinch weld and cut it off, then ground it down with a grinder. I then put the porta power up there and pushed that part of the firewall in some more.
Glenn IIRC you installed IH bellowed up pipes, in the mule right?, with them you didnt have those issues, did you?
Old Dec 6, 2013 | 08:16 PM
  #93
oldbird1965's Avatar
oldbird1965
Almost, I have to finish up the IC pipes on the passenger side and put the rest of the exhaust on. Then a test drive and change the oil. I also never finished the 38 gallon rear tank but that will have to wait until we get back from our trip. Throw on an extra log up there, brrrrr, its even 'cold' down here, LOL
Not one issue Jose except for the price, LOL!
Old Dec 7, 2013 | 05:38 AM
  #94
427 fordman
You're leaving this coming week, right? Where did you say you were going?
-20 this morning, so maybe two more logs on the fire!
Old Dec 7, 2013 | 06:58 AM
  #95
strokin'_tatsch's Avatar
strokin'_tatsch
Eff all that noise. Its 21* here right now and its way too cold. Lol
Old Dec 7, 2013 | 08:37 AM
  #96
oldbird1965
Going to Tucson Thursday, I probably have plenty of time to put the 38 gallon tank in but knowing me, I'll have trouble and don't want it hanging there. Besides, there is lots to do to get ready. It will be a good test run. Also, not taking the Geo, we are buying a bunch of food down there and I need to use all my refrigerators. I haven't figured out how I'm going to connect the batteries and invertor up to run them if I take off rack that holds my generators and batteries.
I must be about 15° colder in Texas then here. I always thought we would be about the same temp.
Old Dec 7, 2013 | 06:05 PM
  #97
BBslider001's Avatar
BBslider001
Well, I know here in Southern CA we are down to the low low temp of 50*. We do have rain though.
Old Dec 8, 2013 | 06:52 PM
  #98
oldbird1965
Got it put back together again. I'll never use saddle exhaust clamps again, only lap type band clams. It wasn't any fun getting the exhaust back on.
I started it up and could not shift it, speedo layed on 90mph, brakes lights stay on, could not rev it up, etc. It was time to go in the house before I did something I would regret later, LOL With the AFE, I feel like a 6637 traitor. At idle, it did sound more quite inside.
Old Dec 8, 2013 | 07:03 PM
  #99
427 fordman
Would something unhooked in the dash cause that? Like maybe he forgot to plug something in?
It should be a lot quieter inside driving. All that insulation has to make a difference too.
Old Dec 8, 2013 | 07:08 PM
  #100
ReBilld's Avatar
ReBilld
That's what I was thinking too Darin....something left unplugged.
Old Dec 8, 2013 | 07:24 PM
  #101
oldbird1965
I'll take a good look tomorrow. As far as the speedo, maybe you have to be moving to get it to reset? Another screw up, I had the map and boost ports mounted way to high, what was I thinking, oh, I wasn't thinking. LOL
Old Dec 9, 2013 | 06:56 AM
  #102
DIYMechanic's Avatar
DIYMechanic
Man that thing looks good Glenn! It's really really clean looking. I'm a fan!
I'm guessing that something is unplugged under there too and the Park interlock isn't allowing you to take the thing out of Park. That should be a relatively simple fix (though it will involve standing on your head...).
Old Dec 9, 2013 | 09:01 AM
  #103
oldbird1965
Thanks Nate, I freshened things up while I had it all apart. Hopefully I can take it for a ride today.
Old Dec 9, 2013 | 09:09 AM
  #104
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Wink
Good luck. And congrats, your truck lucks like a professional work.
Old Dec 9, 2013 | 04:15 PM
  #105
strokin'_tatsch
Too bad the AFE big boost filter won't fit in that box. I like the look of the AFE stage 2 setup like yours. My SD had the old style AFE stage 2 and I yanked it out for a 6637. lol
