Fuel gauge location?
Old Nov 23, 2013 | 06:43 PM
scotttahoe's Avatar
scotttahoe
I just received my Isspro fuel gauge from Riffraff and was curios which port on the fuel bowl to get the most accurate reading, or does it matter? Top driver side is pre filter and lower pass side is post filter. Thinking about going post filter port.
Old Nov 23, 2013 | 06:57 PM
scotttahoe's Avatar
scotttahoe
Sorry, meant fuel pressure gauge.
Old Nov 23, 2013 | 07:02 PM
Shake-N-Bake's Avatar
Shake-N-Bake
Post filter is a good choice since it is out of the way and fairly protected.
Old Nov 23, 2013 | 07:19 PM
scotttahoe's Avatar
scotttahoe
I think thats what I'm going to do. I know it's a little tougher to get to but more protected. Thanks for your quick response.
Old Nov 23, 2013 | 07:52 PM
Shake-N-Bake
It looks tougher than it is. I have the sensor pre filter on my 99 and post filter on my 2000. I will probably move them both to the post filter spot someday.
Old Nov 23, 2013 | 11:50 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Post filter for me. Allows you to see the pressure you are actually getting, vs what the pump is putting out. The difference is filter restriction.
Old Nov 24, 2013 | 04:19 AM
kefrko's Avatar
kefrko
I went post filter when I did mine. I thought it was a little tricky to get to. Hardest part for me was trying to get a wrench that would fit in between all the stuff around it to tighten it. I have been getting a fuel pressure reading of 60-65psi. Do you guys with fuel pressure gauges still replace fuel filter on regular intervals or do you wait for the gauge to start showing a drop in psi?
Old Nov 24, 2013 | 05:07 AM
Tugly's Avatar
Tugly
That's a good question. I replace mine on the odometer, not the FP gauge. If one were to use the FP gauge, they would have to use the WOT method to get an accurate test. If your pressure drops below 45 PSI under normal driving, you've gone way to far... or you're a spunky driver.
The filter is not just about dirt, the OEM is also about water. I don't know the dynamics of the water part of the filter, so I don't push the filter past the recommended schedule.
Old Nov 24, 2013 | 07:53 AM
brwolfjr's Avatar
brwolfjr
This is great information. My Isspro gauge came in from Clay last week and I have not had the time to install it. My question, is there enough lead to mount the gauge in a pod above the rearview mirror?
Old Nov 24, 2013 | 08:28 AM
bigb56's Avatar
bigb56
I went post filter with mine and I used a 45 degree fitting between the adapter and the sender and angled it upwards making more room for the connector.
Old Nov 24, 2013 | 06:26 PM
scotttahoe's Avatar
scotttahoe
Good info, I'm going to try and get mine installed post filter tomorrow and will take some pics.
brwolfjr, I would think there should be plenty of wire from above mirror to fuel bowl.
jt371
16
Sep 10, 2018 02:31 PM
Skydivelout
Apr 30, 2017 12:15 PM
shark1979
Feb 26, 2010 04:29 PM
powerstroke8994
May 23, 2009 11:29 PM
03f2506.0
Feb 14, 2007 04:35 PM
