Radiator question?
Old Nov 23, 2013 | 09:28 AM
Skalywag's Avatar
Skalywag
Radiator question?
Will a 6 cylinder radiator from a 50 f1 that has been reconditioned cool a 302 properly? Has any one used this setup? Thanks for any information.
Old Nov 23, 2013 | 09:43 AM
raytasch's Avatar
raytasch
Believe Nothing
I am cooling my 1949 F4 using the 6 cyl original radiator. I have a large electric fan and modified the original shroud to adapt the fan. I've not driven the truck at road speed but I've let it warm up and sit idling on a very hot day. The 350 CID engine reached the 190 degree thermostat temperature and stabilized. Driving around slowly, temperatures never went above Tstat temp. I seriously doubt if I have a cooling problem when the engine develops full power.
Edit: Pictures if you want to see them.
Old Nov 23, 2013 | 09:57 AM
38 coupe's Avatar
38 coupe
Consider the popularly used 65-66 Mustang radiators used to cool a 302. That radiator is what, half the size of the F-1 radiator? Unless you are doing something really crazy you should be fine.
Old Nov 23, 2013 | 12:07 PM
52 Merc's Avatar
52 Merc
I had a 289/C4 trans combo behind the original 6 cylinder radiator in my 50, it worked perfectly.
Old Nov 23, 2013 | 02:38 PM
oldmerc's Avatar
oldmerc
oldmerc
Stay out of Nevada and New Mexico and you should be fine .
Old Nov 23, 2013 | 03:24 PM
Skalywag's Avatar
Skalywag
Well it sounds like it's been done many times with sucess, so I'll give it a try, but it will be next summer before I find out how it does. Thanks to all that have responded.
Old Nov 23, 2013 | 04:02 PM
49f3dls's Avatar
49f3dls
The biggest problem I had was the bottom outlet is on passenger side and h2o pump on 5.0 is on drivers side. But the cooling is fine again with an electric fan. Have fun
Old Nov 23, 2013 | 07:17 PM
52 Merc's Avatar
52 Merc
I used the conventional fan for years and had no issues. One word of advice, make sure you have the rad support set in the forward set of holes on the frame saddle mount and the corresponding holes in the side skirts to give extra fan room. It's the location used for original 6 cylinder applications. If your truck came with the 6, you're golden. If you had the V8 flattie, it's something to consider and a good option if you find fan clearance a bit tight. Take a look and you'll see what I'm talking about.
Old Nov 23, 2013 | 08:28 PM
Skalywag's Avatar
Skalywag
The truck still has the original six in it. So I can run it without the electric fan, if I fab a decent shroud. Thanks again for the knowledge. I guess that's what you all do best on this board.
Old Nov 23, 2013 | 11:14 PM
Moe Craig's Avatar
Moe Craig
I ran a '49 ford f1 I6 radiator with a 425 Olds Rocket motor and it did fine in the middle of summer in Arizona Heat!
Old Nov 24, 2013 | 08:13 AM
old_dan's Avatar
old_dan
The 6 cylinder radiator will probably cool well, but the stock 289/302 Mustang radiators have been a problem for me. For around the same money that it will take to recondition your stock radiator you can buy a 2 row aluminum radiator. The two rows are twice as wide, so it is the same effect as a 4 row brass radiator.
kens65fb
Nov 7, 2017 09:05 AM
dferrell5
Aug 4, 2014 09:53 PM
wesman76
Oct 1, 2012 12:33 PM
1956bigwindow
Jan 6, 2007 07:58 AM
Racerdave
18
Sep 11, 2003 06:28 PM
