300 6 questions
2wd Dodges have that same type front wheel bearing, with A-arms, while Ford uses the old school inner/outer cone/tapered roller bearings well into the mid 2000's, with the ultra tough twin I beams.
I work on a lot of these trucks. Suspension work on Dodges sucks. Pays well, but will wear you out doing so. Engine work on Fords sucks, as most stuff is rather hard to get to. Again, pays well, but gets old having skinned up hands from reaching into tight places.
However, I'd rather do these, than almost anything on a duramax. Those were NOT designed in a technician friendly manner.......
Yeah, I meant the NV 5600 6 speed. Can be difficult to type with a playful pup jumping on/off my lap, and nosing/pawing at the keyboard. Prolly why it took me 15 minutes to type this reply..........
The GM 2500/3500 4x4 front axle is independant. Rides better, but sure is hard on things when you use it off-road, loaded down.
They have a lot of stuff I don't care for, which is why I have no intention of ever owning one.
A Cummins swap is doable, as there are plenty of adapter kits available. I just can't see downgrading the chassis under such a great engine.......
Cummins in a Ford, is very doable. My boss has an 03/04 (not sure which) F350 4x4 dually, powered by a 12V Cummins, backed by the original Ford 5 speed auto.
Heck, I recently did a bunch of work on a 24V Cummins in a 2001 Dodge 3500. Odometer read 830K, but had been unhooked the majority of the last 3 years. Truck has well over 1M miles on it. Engine is not original, it went out shortly after passing the 1M mark. Just last week, I swapped the injectors for new ones. He had put the original 1M mile injectors into the replacement engine. Considering how cheap (comparitively) they are (under $100 each) I can't understand why he waited that long to get new ones. Powerstroke and Duramax owners would LOVE to be able to get NEW injectors that cheap, rather than $250-$600 each..........
Dodge trucks aren't the easiest to work on. Putting in a heater core requires pulling out the steering column, and removing the entire dash just to access the HVAC unit. Pays 6 hours. 5.75 of that is removing/replacing stuff to get to the HVAC unit. Physically swapping out the heater core takes under 15 minutes, unless you take longer than a 10 minute break in the middle........
All of that said, I would own a Dodge with a Cummins 12V or 24V. Common rail, forget it.
GM truck, not unless it was a very good deal, on something that is in quite good shape. Only one I've ever seen that I would consider, is an 85 K35 pickup I drove back from California for a friend. 6.2L diesel, with a banks turbo. Was originally a military vehicle. Time I got back to OK in it, the odometer rolled up to 15K *actual* miles. It had a 0 in front of the 15,000.......
