Sponsored by: Kumho
leaf spring help
Old Apr 13, 2007 | 07:01 PM
Bulldog187th's Avatar
Bulldog187th
leaf spring help
I bought a used set off a 78 f250 , I got them home and noticed that someone had welded the center locating pin that goes into the perches. They are broke.
I got new half inch by 2 1/2' fine thread ones but they are a little to big to go through the holes.
I have tried to drill them and Im using a new colbolt bit. I cant get through them at all. I have applied drill cutting oil and slow speed but cant get it done.
Any ideas on how to drill them out?
Thanks
Old Apr 14, 2007 | 03:15 AM
75F350's Avatar
75F350
Are you trying to drill out the old center pins, or are you trying to drill the leaf springs to accomodate the slightly larger replacement pins?
If you are trying to remove the old pins that are welded in, you should use a c-clamp to hold the springs together, and drive the pin out with a large drift pin, and hammer. Spring steel is hard to weld to, and the pin will come free with a little help and a good whack with a BFH.
If you are trying to drill the holes larger, just go to the parts supply store, and get the right bolts. They only cost a few bucks, and you will be time, and money ahead by not burning up drill bits. Spring steel is not that tough to get through, but you will still be way ahead by just getting the right bolt.
Old Apr 14, 2007 | 07:49 PM
Bulldog187th
Thanks , I went and got the right size ones.
crazy96863
Jan 30, 2017 10:26 AM
Kyle D
Jan 4, 2017 07:01 AM
Mr. Obvious
Modular V10 (6.8l)
Mar 31, 2016 10:06 AM
joey2fords
Garage & Workshop
26
Jun 15, 2014 06:16 AM
Vinford
Garage & Workshop
16
Dec 26, 2008 01:57 AM
