Newbie
I don't remember the Ex factory codes, because they are junk...
There is another rear code for the 05 and later F250/350's, but don't remember it..
Garry
I have those installed/modded since I couldn't find B codes locally. Luckily is same weight rating
I started my upgrades with a Hensley Arrow hitch with 1400lb spring bars, this made a huge improvement. No more porpoising and not even a hint of trailer sway. Next up was the addition of a Hellwig rear sway bar (our EX did not have a factory rear sway bar) prior to the bar the trailer (9500lb 31" ToyHauler with 1450lb tongue weight) would push the rear of the EX around in corners and downhill curves pretty bad, after the bar was added the rear pushing all but ended. After that I upgraded the EX's weak factory springs (70,000 miles) with a set of X/B codes from a coworker's F-350 that he lifted. I modded the front X codes by adding the top overload leaf from the rear B codes to the bottom of the spring pack. The rear B codes were modded by adding the two bottom leaves from the EX's factory spring pack, the thicker between the leaf spacers from the EX's pack, the taller 3.75" tapered blocks from an F-350 and two cut off sections of the EX's "slapper" factory traction bar. This upgrade made the EX a different vehicle, both running solo and towing. Solo the truck now rides like a truck, I'm OK with that, I like it, some wouldn't.
I also added Rancho RS9000XL adjustable shocks, I'm still playing with the adjustments for running solo but they have helped to smooth the ride for sure. While towing all bad habits are gone, totally, really! With my current setup this EX is a pure joy to tow with, no wander, no sway, no push, no (excessive) squat, no bad manners. 65 MPH with big rigs passing is a one finger on the wheel rock steady non-event. This Wednesday will be the last time I tow that trailer
, it's being traded in on a new 39' Jayco Eagle
so I'll be doing a little tuning to get the new combo just right, should be failrly easy with all the proper goodies onboard.Around here everyone talks about various spring "codes" so here's the skinny on them. The codes are from Ford and it's how they ID the different springs put on trucks at the factory based on all the various options and motors.
The following only applies to 4X4 EXs, the 2X4 rigs have coil springs up front. All EXs came from Ford with G code rear springs, the V-8 EXs all came with B (front B code is much different than rear B code, confused yet?) 4100lb, all V-10 EXs came with C code fronts at 4300lb and all PSD EXs had D codes at 4700lbs.
All the other codes discussed come from SuperDuty trucks (they came with springs that don't suck from Ford.)
Spring........Capacity.....Rate lbs/".....Max travel.....V-10 change.....PSD change
B (V-8)......4100lbs.......330 lb/".........5.02"...........-0.25".............-0.66"
C (V-10)....4300lbs.......350 lb/".........5.01".............0.00"............-0.37"
D (PSD).....4700lbs.......380 lb/".........5.14"...........+0.33".............0 .00"
S codes.....4000lbs.......370 lb/".........4.34"...........+1.22"............+0 .88"
T codes.....4400lbs.......390 lb/".........4.63"...........+1.42"............+1 .11"
U codes.....4800lbs.......410 lb/".........4.89"...........+1.60"............+1 .32"
V codes.....5200lbs.......430 lb/".........5.13"...........+1.77'............+1 .50"
W codes....5600lbs.......450 lb/".........5.34"...........+2.77'............+2 .52"
X codes.....6000lbs.......470 lb/".........5.54"...........+2.90"...........+2. 68"
W codes are from F-450s and X codes are from F-550s and other SD trucks with snow plow prep. The above spring info has been gathered from posts here on FTE by "monsta" and "bruce1954".
Make sure your EX has load range E tires on it before towing that large (nice) trailer and be sure to run the trailer tires (if type "ST") at max pressure as listed on their sidewalls.
Wander/towing
Start....
Rear sway bar
New bushings on front sway bar
New rancho shocks
Then....
V/b or x/b swap
Airbags
New tow hitch(probably Reese dual cam)(prefer Hensly but a little pricy)
Thoughts?
Wander/towing
Start....
Rear sway bar
New rancho shocks
Then....
V/b or x/b swap
Airbags
Thoughts?
Looks like a good plan. Don't be too quick to rule out the Hensley or it's cousin Pro-Pride, search around on Craigslist for used units. I bought mine off CL for $650 and then I did a little refurb work to make it look and work like new. You may not need the airbags with the correct size WD spring bars and the rear B codes. My modded B codes handle my 1450lb tongue weight fine with about 2" of squat. I built extra ride height into my spring swap to allow for the squat, I wanted it to ride nearly level while towing.
Thanks....I've been searching the web for them and haven't ruled them out. Just not a new one. Too pricey. For my budget anyway.
Only you can make the call on how your EX feels pulling your trailer, and if I remember correctly your TT is fairly large. Have you pulled it yet, how was it?
For me only towing 7500 or so, I opted for the Modded B AND air bags.
