Defrost snow ingestion and Dust ingestion through heater
#76
I also have submitted a claim and have also been given a case # and CSM. BUT after a short few weeks they closed my case and left me with nothing to work with. No call backs, no replies to emails nothing.
Hopefully I can get something sorted out.
Keep in touch with your findings if you don't mind.
And of hand, the website you used to submit your claim was?
I asked them to clarify how this TSB addressed the concern of snow ingestion. They said they would try and get a clearer understanding from Ford. This is the direct response from Ford Engineering:
“Comment From: Ford Comment Date: 4/29/2014 1:40:27 PM
Hello,
The TSB states ice accumulation due to the collection of snow entering the HVAC case turning to ice freezing the HVAC components. The new HVAC module will default the mode door to recirc mode when the key is turned to off position to prevent snow from entering the HVAC case. The previous HVAC module defaulted the mode door to fresh air mode allowing snow to enter the HVAC when the key is turned to the off position. The new module will prevent this concern from occurring."
So even though the TSB doesn't specifically talk about snow ingestion that in fact is the root cause. Bring up this TSB # with your ford dealership and see what the response is. I'm sure if they contact Ford directly you'd hope they are given the go ahead to replace it and if the above info is correct the problem should be corrected.
Please let me know what happens. Feel free to message me back as well. And the bottom line is we won't know with absolute certainty until next winter.
As a result I'm not continuing with the CAMVAP claim at this time.
Good luck!!
#77
Just had mine fill up with snow and freeze up the "Blend door".
It was blowing nothing but outside air at -25c on any setting. After running the truck with the fan turned off and a heat gun blowing down into the cowl grille for about 30 minutes it thawed out.
This shouldn't have happened, and I'm now looking into a way to add a cabin filter so it doesn't happen again.
#78
Got my truck back after 2 weeks in the shop. Has a new blower case and all the HVAC actuators have been replaced for good measure. Winter is over for the most part so not expecting to be able to validate the fix any time soon. Have to wait for fluffy snow next year, i suppose.
This is decision point, gentleman.
- Put up with the worst HVAC system (summer and winter) I have ever experienced.
- Sell and get something other than an F150.
- Make a homemade cab air filter.
Another factor is I waited 3 years for my damn stock tires to wear enough so I could justify buying some cool tires. And I've waited 3 years for my warranty to expire so I could finally use an engine tuner. If I sold now it feels like I am denied my fun! LOL
#79
ktm4012
06-19-2016 12:15 PM
JDJINTX
11-03-2006 12:16 AM
cowboywanabe
03-05-2003 10:06 AM
