engine surge
Old Nov 21, 2013 | 02:06 PM
dirkdriller's Avatar
dirkdriller
engine surge
2000 excursion has engine surge at idle in drive at stops. Engine runs great other than that. It only does it in drive. Doesn't do it in reverse. Weirdest damn thing! Come on with a solution.....
Old Nov 21, 2013 | 04:05 PM
DND58's Avatar
DND58
Try unplugging ICP sensor on drivers side head. Look for oil in connector, and see if idle smooths out.
Old Nov 22, 2013 | 11:39 AM
dirkdriller
That didn't help. Funny thing is the rpm will dip to 500 and rise to 800. It does it slowly and only when in drive at idle. I did have a p0605 internal pcm rom failure code. I removed the banks power chip and the code went away, but the idle surge is still there and not all the time. Now the transmission was rebuilt not too long ago. It's almost like the transmission is being shifted from drive to neutral over and over again, but without the out of gear feeling.
Old Nov 22, 2013 | 01:38 PM
Christof13T's Avatar
Christof13T
Auto or handshaker?
There is a "turbine speed sensor" on the tranny that can cause idle surge and even the "romp romps".
I think that pertains to the manuals but it may be on autos as well...
Drivers side... close to bellhousing on almost the top of the tranny...
Somebody jump in and correct me if im wrong... its been quite a while since i messed with one.
Old Nov 23, 2013 | 11:30 PM
timf150's Avatar
timf150
Subscribing...
Old Nov 24, 2013 | 02:58 AM
Stewart_H's Avatar
Stewart_H
Originally Posted by Christof13T
Auto or handshaker?
He has an Excursion, so it's a 4R100. No Excursion came with a manual trans.
Stewart
Jhughes4707
2004 - 2008 F150
May 26, 2021 06:08 PM
1olddogtwo
Oct 14, 2020 12:16 PM
Fordenthusiasts
May 10, 2016 10:28 PM
Lastwagen
6.7L Power Stroke Diesel
Jul 16, 2012 08:02 AM
uscrpick
1978 - 1996 Big Bronco
May 6, 2006 12:43 PM
