Got a strange issue with my rear taillights. Brake lights and turn signals work perfect with the head lights off. Turn them on and it seems like I'm not getting enough voltage. The taller of the two filaments on the 1157 bulbs seems to be lighting but real dull. Before I go on a goose hunt tracking the wires back into the cab I'd figured I'd ask see if there is a common problem. Maybe a place I should start?
Thanks
Also so I don't make another thread im looking for the fresh air vent that goes under the dash on the drivers side. Don't know what its exact name is but I haven't seen one in LMC or JBG.
Thanks
You didn't actually say what the problem is, other than to say "strange issue" and "seems like not enough voltage" which I don't understand what that means, unless you're actually measuring a voltage, for which you provided no details.
I'm going to take a wild guess and assume you mean your brake lights are dim with the headlights ON yet full brightness with the headlights OFF. Am I right? Replace both rear tail light sockets. You have ground shift. 99% of the time, it's due to corrosion within the ground connection of the socket itself.
Replace the sockets; don't worry about the headlight switch.
Sorry looks like I didn't explain it very well. I said " The taller of the two filaments on the 1157 bulbs seems to be lighting but real dull."
When the lights are off the longer filament (brakes, blinker) works fine and lights bright but when you turn on the head lights the smaller filament (running lights) seems to be taking all of the power from the taller filament (brakes, blinker) and will hardly light up. So they do work but like they aren't getting enough power. That make more sense?
The sockets look great, no corrosion, could they still be bad?
Thanks for the clarification; I probably didn't read your post as closely as I should have.
Yep, and just as I expected, that's ground shift. That's because of common impedance between the two filaments. One filament wants ground to be at zero volts, but the other filament is "shifting it up" due to return current through the common impedance. That leaves less voltage available to drop across either filament.
How something "looks" visually is meaningless in terms of electrical conductivity. The only metrics that mean anything here are measurements taken with a multimeter. If you want to be extra cautious, you can ohm out the socket with a multimeter. Of course, there's still the possibility that the sockets are fine, but they are not grounded properly externally. You can verify this as well, but as I alluded to earlier, that scenario typically accounts for only 1% of real cases.
I'm not aware of any aftermarket versions. I got one off ebay.
