Spark Plugs
Old Jun 23, 2003 | 06:22 AM
FyreLyter's Avatar
FyreLyter
Spark Plugs
I need to change my plugs...I need to change my plugs...oh boy I need to change my plugs. I have a '98 xlt 2.5L supercab. Nice truck, and has been through a lot, and will probably go through much more before it's ready to leave me. I'm looking for suggestions, know-how, help?, on how to change my plugs in an easy, straightforward manner. The 8 plug configuration on my ranger has left some hidden under and around the intake manifold... any suggestions before I start?
Oh, yeah another thing, what type of plug would you recommend for a hard driving ranger? I'm looking for a little boost in performance. Are those bosch platinum with the multi-tips any good?
Thanks for any help you can give...
Old Jun 23, 2003 | 06:41 AM
G. Martin's Avatar
G. Martin
Spark Plugs
I have only been a member here for less than a month. but I will tell yo to try the search I found so much valuble info on the subject of changing the spark plugs,and the spark plugs them selves. good luck and happy searching.
Old Jun 23, 2003 | 12:52 PM
Ken00's Avatar
Ken00
Spark Plugs
Welcome to FTE!!!
No tips on changing them but I would stick with Motorcraft double platinums, its very important to have the double with the DIS ignition system.
Old Jun 23, 2003 | 02:26 PM
FyreLyter's Avatar
FyreLyter
Spark Plugs
Thanks my friends, knowledge is power!
Old Jun 23, 2003 | 03:42 PM
nightme_02's Avatar
nightme_02
Spark Plugs
I have a '94 with a 2.3. When I change my plugs I only use Bosch Platnums. They work great, and gas milage is about 23-24...as far as getting to the things...that is a little more difficult. I usually take the throttle body and upper intake off, I have found that a really really long socket extension works (12-18 inches) and that cuts the time in half. But that is on a '94, and I don't know how the '98's under the hood looks?! Food for thought!
Old Jun 23, 2003 | 07:00 PM
bubbernator's Avatar
bubbernator
Spark Plugs
I agree with Ken00 about the MotorCraft Double Platinums. Fortunately they last about 100,000 miles, so you don't have to buy them often.
I usually pull of the throttle body and upper intake manifold to get the driver's side on my '98 2.5L. The factory wires have handles on them and you may get lucky and not tear one loose, but then again, maybe not. The third one back is very tricky with the manifold in place.
There are severals vacuum lines to disconnect and the manifold is liquid cooled, so there are the coolant lines to deal with. You'll need an uppder intake manifold gasket kit. While you have it off, it's a good time to clean the throttle body and manifold. Also the PCV valve is located down low on the driver's side. Replace it, too. And don't forget the silicone boot grease.
Good Luck.
CB
Old Jun 23, 2003 | 07:15 PM
FyreLyter's Avatar
FyreLyter
Spark Plugs
If I'm going to take off my manifold, which I think I'll do...what do any of you guys think about throttle body spacers that I guess spin the air or whatever adding more performance? I guess I'm asking what is it that they really do and if they work? I might as well put one on if I have it exposed to do so...
Thanks...
Old Jun 23, 2003 | 08:19 PM
Ken00's Avatar
Ken00
Spark Plugs
Don't forget about putting dielectric grease on the boots when you put hem back on.
Old Jun 24, 2003 | 01:48 AM
FyreLyter's Avatar
FyreLyter
Spark Plugs
dielectric grease? not just silicone boot grease?
Old Jun 24, 2003 | 01:52 AM
PT17Pilot's Avatar
PT17Pilot
Spark Plugs
If the 2.5L is like the 2.3L I have, I use an 18inch extension with a swivel spark plug socket. Wrap the swivel with a few wraps of masking tape. The tape will let it swivel, but hold it straight enough that you can fish it down on top of the plug. It also makes reinstalling them easier for the same reason. Get a long pair of needle nose pliers for the wires on the drivers side. After I quit scratching my head and just dove in, it was really straight forward and didn't take much time at all. If you do decide to remove the intake, make sure to use new gaskets on the reassembly. Hope it helps!!
CJ
Old Jun 24, 2003 | 06:52 AM
Rockledge's Avatar
Rockledge
Spark Plugs
Read Here: Dielectric Grease Thread
UrbanXX
Jun 2, 2010 03:29 PM
amtraktrekker
New Member Introductions
Jan 25, 2009 08:23 AM
69ford99
2004 - 2008 F150
42
Aug 22, 2008 03:28 AM
FordExplorerMan
May 27, 2004 09:31 PM
Brettr
Jan 23, 2003 05:05 PM
