Head Work
Old Nov 22, 2013 | 03:35 PM
bradb2230's Avatar
bradb2230
Originally Posted by yetiman38237
I have a buddy that has a set of 390 heads he took off his 73. Does anyone know if they have hardened exhaust seats already ?
I don't think it was until 1975 that the FE heads came stock with hardened valve seats. Up until then everything ran leaded gas, and it is for this reason the older heads need the hardened valve seats. We can't get leaded gas anymore. That is not to say that someone had not rebuilt the heads and put the seats in. My engine had never been overhauled up until now, so my valve gaskets were gone, my valves had "Ford" in raised lettering on the face, and my rod and main bearings has "Ford 1970" stamped in them.
If you find a shop that has the iron heads in stock and will do a swap with you, that would be a good way to go. I didn't have that option in my area, because 98% of the people around here that are building the 360/390s are building them for dirt racing, and ditching the iron heads for the higher performance and liter aluminum heads. They are also rebuilding their engines after every race. For reliability and longevity stick with the iron heads. If you do it right you will have an engine that will give you another 500k+ miles without any troubles.
Old Nov 22, 2013 | 07:01 PM
orich's Avatar
orich
Aw guess you've never read any of Steve Christ's Book on Fords Big Block engines. Then you've know when harden seat were installed ..
Orich
Old Nov 23, 2013 | 07:29 AM
yetiman38237's Avatar
yetiman38237
That is one book I want to buy......
Old Nov 23, 2013 | 10:20 AM
orich's Avatar
orich
Also another great book is FORD PERFORMANCE by Pat Ganahl \
A better book for engine specs.
orich
gthiboy
Feb 20, 2011 05:41 PM
gungho351
21
Jan 2, 2009 11:11 AM
C-Leigh Racing
Nov 14, 2008 11:01 AM
RC Dan
Oct 21, 2007 12:30 PM
woodsrider505
Dec 6, 2004 05:02 PM
