Transfer case shifting
Old Nov 20, 2013 | 12:11 PM
duggyb's Avatar
duggyb
I bought the truck in my signature back in spring. The 94.5 and it never had any of the linkage for the transfer case because the previous owner broke it.
I am heading up to my brothers farm where my parts truck is located to get those and some other parts which is the 95 in my signature. And they are calling for lots of snow.
I am just wondering if the roads get hairy can I put a pipe or piece of something on the little metal arm coming out of the t case and shift it into 4 high while underneath the truck? Or do I need that aluminum linkage piece that mounts to the tranny?
I assume I can just pull back one notch to get 4 high going.
Any insight would be great thanks
Dustin
Old Nov 20, 2013 | 03:36 PM
ReBilld's Avatar
ReBilld
Should be able to reach up and shift it by hand. If it is real stiff you may have to use a pair of channel locks or something, but it shouldn't be a problem. Your sig is not showing up, so I don't know what the trucks are, but the auto and manual trans take a different length linkage bar that goes from the shifter to the t-case.
Old Nov 20, 2013 | 03:41 PM
woodtrucker's Avatar
woodtrucker
^ what Bill said!
Old Nov 20, 2013 | 03:50 PM
duggyb's Avatar
duggyb
Good to know. And both trucks are cclb zf5 4x4s so linkage should be the same. Only difference is 94.5 is my current rig and my old one is a 95
Thanks guys
Old Nov 20, 2013 | 04:33 PM
woodtrucker
If u do crawl under and shift it, if its like mine, it will be hard to get it in 4wheel high. Everytime i tried to shift like that i would pull lever and overshoot to neutral. Good luck!
saskwaterfowl
1997 - 2003 F150
Feb 9, 2020 02:23 PM
CrappyPappy
May 4, 2016 04:58 PM
Lazy_pig
25
Feb 5, 2015 11:00 PM
34dawg
May 25, 2010 08:10 PM
