Rough running problem
Old Nov 20, 2013 | 11:13 AM
atomicglock's Avatar
atomicglock
The hits just keep on coming with this truck, both minor and major.
Some of you may remember my thread on battery replacement a couple weeks ago. Well, now I've got a different problem.
Lately, when I cold start the truck and drive it, it stumbles and runs like the engine is missing until it warms up. So, I did a little research and decided, before I posted, I'd check the FICM voltage.
The instructions in the tech folder say to unbolt the coolant reservoir and "...move it forward and to the right" and that it was not necessary to remove any hoses. Not happening on my truck. I can move it about 2-3" forward but it will not go to either side. Consequently, I'm unable to access the inspection plate on the FICM.
So, once more I ask the brains of FTE, What am I doing wrong here?
Old Nov 20, 2013 | 11:53 AM
amdriven2liv's Avatar
amdriven2liv
I'm hitting easy street
Start at 1:10 of this video, you do need to disconnect one hose. And, you will need a second person to help with testing. Also. put a piece of tape around the probe to help keep from shorting it against the case of the FICM. When you have the probe in place, have the other person turn on the key. A FICM can go from 30v to 48v in about 10 seconds. It takes longer than that to go from cab to probe FICM and you might miss this issue.
Old Nov 20, 2013 | 11:54 AM
clevelandtundra's Avatar
clevelandtundra
There should be two small bolts that hold the degas bottle in place from the topside? If you need, you can remove the two thin hoses coming in and move them out of the way and it should allow you to wiggle the bottle and move it pretty easily. I changed the FICM this way without removing the bottle entirely.
Old Nov 20, 2013 | 02:08 PM
atomicglock
Ford 6.0 FICM Testing & Removal Instructional Video - YouTube
Ok, that's what I thought. Tech folder said I didn't have to remove any hoses, though I'm not sure my coolant bottle will slide as far forward as is shown in the video. I'll try it again tomorrow. Thanks.
Old Nov 20, 2013 | 09:10 PM
mhoefer's Avatar
mhoefer
Yeah, it requires draining coolant amd then disconnection the tube under, but the vent line on top can stay connected with the cap on so you can flop it up or over onto the engine.
Old Nov 21, 2013 | 03:44 PM
atomicglock
Ok. Disconnecting that one hose made all the difference. Checked the voltage and it was a consistent 48.4v during the entire test.
I put Hot Shots Secret in at last oil change in May. What could be causing the stumbling? Only seems to happen when the truck is cold. Warmed it up this morning for 15 minutes before driving this morning and it ran fine.
Old Nov 21, 2013 | 03:46 PM
npccpartsman's Avatar
npccpartsman
Injector stiction.
Old Nov 21, 2013 | 05:03 PM
atomicglock
Originally Posted by npccpartsman
Injector stiction.
Even though I ran Hot Shots Secret through it all summer?
Old Nov 21, 2013 | 05:15 PM
npccpartsman
HSS is a bandaid at best. It won't fix a mechanical problem. It might help for a while. Polishing the spool valves might help.
Do you know what flash is in your truck? It's possible a FICM flash might fix a lot of it. What oil are you running? Mileage on your injectors?
Old Nov 21, 2013 | 06:35 PM
atomicglock
No idea what flash, but, it was updated Mar. of 2012. I have the service invoice. If it's on there, I'm not sure how to read it.
Running Rotella T6 5W-40 syn. Have since I bought the truck.
Injectors have not been changed since I've owned the truck. No idea what the previous owner did. Trucks got around 93,000 mi.
Old Nov 21, 2013 | 07:00 PM
npccpartsman
If it was reflashed in 2012 it's got the latest flash. As you said, you have no idea what the PO did. You're only recourse is to take it to a competent 6.0 TECH and have a power balance test run when it's cold.
Have you code scanned the truck?
Old Nov 21, 2013 | 09:01 PM
atomicglock
No idiot light so I assumed it hadn't thrown a code. If I'm incorrect about that I can have it checked tomorrow.
Old Nov 21, 2013 | 11:27 PM
9228.bobcat's Avatar
9228.bobcat
Hot shot secret sucked for me, didn't do anything. I kind of sound like a broken record but archoil 9100 works great. If u can remove the varnish off the spool valves it's not a band aide fix.
Old Nov 22, 2013 | 04:14 PM
atomicglock
Lemme bump this back to the top and ask again. Will the truck trow a code without setting off an idiot light?
Old Nov 22, 2013 | 04:15 PM
npccpartsman
Yes it definitely can...
