My 73 ranger xlt
Old 11-19-2013, 02:32 PM
Cman8469's Avatar
Cman8469
Cman8469 is offline
My 73 ranger xlt
I have to say this is my first post, I've started rebuilding my dad's 73. It sat untouched for about 7 years , but after very little work I was able to get the beast started. After driving it a while the leaks from worn out gaskets and dried up seals make themselves known. After about 6 months I started having problems with the rear end (9" 10 bolt ). I start into it tearing it down to find that it was all original and worn out. You hear people say that the 9" is the one to have , but is it worth rebuilding or should I go another route and replace it to possibly safe money? Any thoughts or suggestions will be helpful.
Old 11-19-2013, 03:03 PM
HIO Silver's Avatar
HIO Silver
HIO Silver is offline
The Ford nine-inch is a tough axle. Have the center section rebuilt by a reputable shop (unbolt it and drop it off - try that with a Dana or 8.8!) and consider changing the gears depending on its planned usage. (MPG vs performance)
The rear housing and axles are easy enough to freshen up with new seals, bearings, and brakes. It does require a shop to press on the bearings unless yer set up to do it yerself which is kinda doubtful for 90 percent of us.
Alternatively, head to the JY and pick up a used center section. About $200 from the yards I frequent. It's still a risk .... might eke out a few miles or go for thousands of miles. Do your homework on testing it at the JY before the purchase.... Heck, bring some geartooth compound with ya to check the tooth pattern.
Oh.. welcome to FTE.
Old 11-19-2013, 03:05 PM
arctic y block's Avatar
arctic y block
arctic y block is offline
Could we see some pictures? Here is how.
But I got ta say becoming a supporter is the fastest and easiest way to post pics right from
your whatever pad/cell thing or home computer.
Few of us look in the users Gallery or album as you can see by your recent visitors.
Quote:
Originally Posted by 76f350spercamprspeal
Welcome to FTE, Best Damn Forum EVER!
Here's How to Post Pictures:
1. Login to FTE.
2.Click User CP (In the Top Left Hand Corner)
3.(On the Left, There will be a list, The 5th Option Down, will say "Pictures & Albums) Click That.
4.Then, Click Add Album, Enter a title, and description, if ya want to.
5. Click Upload Pictures, Then click Browse, Locate the Files of your truck. (You can add 3 files at a time)
5. Click Upload.
6. Add a description to the individual pictures, then click save.
7. Add more files if ya want.
8. Click The Picture you want to post, it will give you two codes at the bottom, Right Click The Second one (It say's BB Code, Then Say's [IMG]http:blahblahblah...[/IMG])
Then, Once that is highlighted, Right Click, Then Copy, Then Paste it into your post.
You can add up to 30 Images in one FTE Post.
If, Ya need any help, Don't hesitate to ask.
Quote:
Originally Posted by old_dan
You can also go to the "Garage" tab and start an album right here on FTE. After you post pictures to an album, we can look in your album, but you'll also be able to "insert a picture" by pasting in a link to the picture in your album.
It seems awkward, but whenever you "insert a picture" to one of these threads, the forum is looking for the picture somewhere on the web (which is always available) rather than from somewhere on your hard drive (which isn't always available).
Quote:
Originally Posted By Jolly Roger Joe
Welcome to FTE!
Go to Image hosting, free photo sharing & video sharing at Photobucket and sign up for a free account. Then create an album for your truck. Upload any pics you want to post on FTE to that album. Have this album open on your computer when you want to post pics on FTE.
While you're making a post on FTE, select the pic you want to post from your Photobucket album. When the large version of the pic is open, right mouse click on it and select "View Image Info". The image info will be highlighted and will look something like this:
The best photos and videos | Photobucket
Copy that highlighted info (right click / copy).
When you have the spot in your post where you want the pic to be placed, select the "Insert Image" icon at the top of the post (looks like a mountain) and paste (right click / paste) the image info you copied in the highlighted box (just shows "http://" when it opens).
Your pic will be placed in the post.
Hope that helps.
Here's a tutorial Bob put together: https://www.ford-trucks.com/forums/67...-pictures.html Bob's link is not working. Can someone in the know tell me why?
How to upload pictures to the FTE Forums. - YouTube. Thanks Sam Rusty_Old_F250. Best we can find is that this video was done by Gundown64
Old 11-22-2013, 10:36 AM
Cman8469's Avatar
Cman8469
Cman8469 is offline
Thanks for the advice and I will post some pic's as soon as i get the rear end back under neath it. I'm excited to work on the beast and appreciate the input .
releep51
04-28-2014 10:16 AM
fabieber
01-09-2014 03:13 AM
tip49
11-15-2013 12:12 PM
Gear Up
04-15-2013 09:58 PM
flyin 51
10-04-2012 12:01 PM
Quick Reply: My 73 ranger xlt
