1978 - 1996 Big Bronco
Starting Problem
Old Jun 22, 2003 | 08:55 PM
billsmithhd's Avatar
billsmithhd
Question Starting Problem
I am stuck, I bought new starter, solenoid, and cables. Every time I turn the key everything shuts down, and it doesn't start. But I can disconnect the battery and reconnect it and everything comes back on as long as I don't try to start it. I have spent a week under and around this truck trying to figure it out. I know it must be something stupid, But I am a Harley Mechanic, not a truck Tech. If there is any help you can give I woould be in debt to you.
Thank You,
-Bill
Old Jun 22, 2003 | 09:52 PM
c96drumm's Avatar
c96drumm
Starting Problem
Have you tried starting it by jumping the solenoid terminals with a screwdriver? If this works, might be a problem with the ignition switch.
Old Jun 22, 2003 | 10:14 PM
Mil1ion's Avatar
Mil1ion
Starting Problem
Have you removed both battery cables and cleaned them up really well?
Have you also cleaned the battery posts up real good?
What is the condition of where the battery cable end is attached to the battery cable? Corroded ?
Make sure the battery is in good condition as fully charged before trying it again.
If after you have cleaned and re-attached the cables tryit.
if it still won't kick the starter over, Take a wire from the + battery post and touch it to the S terminal of the starter relay.
Please do this and get back to report your findings.
Old Jun 23, 2003 | 06:50 AM
billsmithhd
Starting Problem
I cleaned the post and cables, one seems a little torn up, I will get another today. Try to jusmo to the S terminal and nothing but spark, could it be ground. I will try today. I will let you know what happen.
Thanks,
-Bill
Old Jun 24, 2003 | 09:40 AM
billsmithhd
Starting Problem
Got it. I replaced all cables, and it was neg cable to block. Well now I can sell this hing. Thanks everyone.
-Bill
XenonKilla
Dec 12, 2019 10:27 PM
SeaCarr
Feb 15, 2015 11:58 AM
monkeyjeep
Nov 16, 2014 03:58 PM
firefighterwilbanks
17
Nov 27, 2012 06:44 AM
XenonKilla
Electrical Systems/Wiring
Apr 8, 2010 02:48 PM
