Smoke
Old Nov 16, 2013 | 07:00 PM
yasky69's Avatar
yasky69
Smoke
I have a 03 350 with the 6.0. 125K
I've been noticing it running a bit different lately.
For the last week or so we've had colder weather and I've started the truck up a few times over the cold spell. After the glow plug light turns off I've turned the key and it doesn't want to start unless I feather the fuel pedal. But on the warmer mornings it starts up fine.
Secondly, today after the truck was warmed up and running at normal temps I had stop at a stop light. Upon making my turn and accelerating I looked in the mirror and noticed blue/white smoke. Went away 20 seconds later an haven't had it since.
So when I got home I jumped on the forum to do some searching. Is it safe to say at this point my EGR Valve may need a good cleaning and look for the possibility of the EGR Cooler beginning to go bad?
Old Nov 16, 2013 | 07:05 PM
jf490's Avatar
jf490
I'm still a new-b so my info could b Completely wrong
Any how I had the same symptoms on one of my trucks turned out it was the ficm also known as the injector drive module
The colder it got the more it didn't want to start and once it got cold low 40's she wouldn't start at all just crank
I would look into that
There are ways to "test" it I've herd of ppl using a multi meeter
I just plugged a scanner into my truck and it ce up with a ficm code
Hope this helps out
04badford's Avatar
04badford
Hows the FICM reading ? EGR could be sooted, any Gauges to read live data?
Old Nov 16, 2013 | 07:08 PM
yasky69's Avatar
yasky69
Only gauges would be those in the dash. No tuner... however I do have a OBII scanner for the gas cars. Could I use that?
Old Nov 16, 2013 | 07:11 PM
04badford's Avatar
04badford
does it read cansef, you will need a scan gauge or dash boss , the Ficm should not drop below 45 at anytime how old is the two batteries?
Old Nov 16, 2013 | 07:19 PM
yasky69's Avatar
yasky69
Probably not.. not sure what cansef is but I'll search it out as I just did the FCIM test procedure.
Both batteries were new last May 2013.
Old Nov 16, 2013 | 07:24 PM
04badford's Avatar
04badford
What reading did you get from FICM main? with the gauge cansef is what our trucks obd port enter info for the gauge, also there's FICM lp ( logic power) and FICM vp ( vehicle power ) to get Info values aswell.
yasky69's Avatar
yasky69
ok according to actrons website, my scanner is CAN compliant. I'll plug it in a see if it says anything, thanks
Old Nov 16, 2013 | 07:28 PM
04badford's Avatar
04badford
I could be wrong but I don't think that gauge will work, we have to enter the ford X Gauges into the scan Gauge to read all the senser data.
Old Nov 16, 2013 | 07:32 PM
yasky69's Avatar
yasky69
Your right. Scanner will only pull codes,I/M monitors,Mil Status. Pretty much useless. I guess I can't do anything until I get the correct tool. I'll look into the ones you've listed.
Would the SCT tuner work?
Old Nov 16, 2013 | 08:44 PM
04badford's Avatar
04badford
Sorry had to put my feed bag on ( dinner) lol sct live wire I belive so , I just have the Scan Gauge from Auto zone, dash boss and the others I'm not familiar with hopefully Josh or the guys will chime in to help you on the gauge choise, Did the scanner pull a code? you can always have Auto Zone check for codes then write them down
Old Nov 16, 2013 | 08:53 PM
BLADE35's Avatar
BLADE35
God this thread said smoke I thought you all meant something else
Old Nov 16, 2013 | 08:57 PM
BLADE35's Avatar
BLADE35
If its an OBDII scanner then Yes
But you need a ScanGaugeII or Dashboss
You can get SGII faster at Auto zone
But the Dash Boss is a Better unit
Neither on will do cylinder balance test so if its an Injector going then might have to do some old school tests
BUT DEFINATLEY PLUG your Code reader in see if you get a Code/DTC
Old Nov 16, 2013 | 09:02 PM
04badford's Avatar
04badford
These are the Values you want to Ideal see at koeo,low,high
FICM ( main)-koeo-47 lo-47.5 high-47.5/48
FICM (lp)-koeo12.0 lo-13.5 hi-13.5
FICM (vp)-koeo-12.0 lo-14.0 hi-14.0
just because the main is showing 47/48 remember that vp and lp maybe showing less.
If you pull the EGR valve clean up the MAP to intake follow the hose down to the Intake there's a nipple threaded into the intake that gets clogged also the IAT2 senser witch is behind the fuel bowl chances are that's caked too. Try not to get CARB cleaner into the electrical of the sensers and valve I use a small plumbers flux brush too.
Old Nov 17, 2013 | 12:13 AM
Yahiko's Avatar
Yahiko
Benny you know that stuff is legal up here in Washington?
To the OP if you have the 06 I see in your about me. You can use one of
the older Snap-On Red Bricks aka The MT-2500
with the last update that they made for it and a CAN-1B adapter. That is what
I used to use. It worked for most things.
Sean
