fuel pump outlet fitting size
Old Nov 16, 2013 | 12:34 PM
Sooper Camper's Avatar
Sooper Camper
what size and thread pitch is the outlet fitting on the stock style fuel pumps? i know it uses a flare fitting, but i'm trying to convert to AN lines and need to know what male to male adapter to source.
Old Nov 16, 2013 | 01:57 PM
fmc400's Avatar
fmc400
MSEE
The most common inverted flare fitting for 5/16" tubing is 1/2"-20 for this application.
Old Nov 16, 2013 | 03:05 PM
Sooper Camper
so, I just checked the fitting that I pulled out and it looks to be 7/16" fine thread?
Old Nov 16, 2013 | 03:17 PM
fmc400's Avatar
fmc400
MSEE
Are you asking a question?
Old Nov 16, 2013 | 05:56 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Does your fuel pump have an integral filter on the bottom of it?
If it does the outlet has a replaceable fitting that, on the pump, is 1/8 FPT.
The fitting itself is 1/8" MPT X 5/16" inverted flare. I don't have my books handy right now, I'm in the middle of a road trip so I can't say for sure what the actual thread size is.
EDIT:
I did a quick lookup on a chart I have and it says that a 5/16" inverted flare uses a 1/2"-20 thread like fmc400 said.
Old Nov 16, 2013 | 10:04 PM
Sooper Camper
i suppose. you said 1/2" x 20, but the threads on the fitting i pulled off are 7/16" x 24. i was curious if there was some variation in the fitting over the years?
i probably should have mentioned it is on a 460, and it does not have the integrated filter on the bottom like the FE in your picture (i have one of those on the 390 in my bird so I do know the difference).
Steves55
Dec 19, 2017 06:19 PM
93f1505.0L
May 17, 2010 08:35 PM
Icefire
Feb 14, 2009 01:55 PM
DeathMobile
Apr 30, 2003 03:01 PM
