Sponsored by: Real Truck
Doing front ujoints, what else should I check?
Old Nov 15, 2013 | 06:28 PM
sg2004's Avatar
sg2004
'04 f250 5.4L 122K miles. all ball joints were done maybe 15K ago and pads and rotors just before that. What ujoints are the better ones? I know to replace the dust seal, the large seal next to the ujoint, and the yellow seal. what else? thanks
Old Nov 15, 2013 | 06:40 PM
PSDlongbox's Avatar
PSDlongbox
I like Spicer joints personally
Old Nov 15, 2013 | 06:47 PM
sg2004's Avatar
sg2004
OK Spicer greasable or non?
Old Nov 15, 2013 | 07:08 PM
PSDlongbox's Avatar
PSDlongbox
I always switch to greasable when available. I think its stupid they aren't greaseable from the factory, but I digress.
Old Nov 15, 2013 | 07:17 PM
03F350XLT's Avatar
03F350XLT
I used napa greaseable. Since your ball joints are new other then the knuckle and dust seals you mentioned.....grease your wheel bearings through the abs hole.grease the caliper slide pins. Inspect outer axle stub shaft and replace needle bearings. Make something up to clean out the axle shaft tube prior to reinstall, and replace yellow wheel bearing oring and black 4x4 hub oring. Mine as well service/grease the 4x4 hub while its out. I just did this repair last year. Enjoy
Old Nov 15, 2013 | 07:29 PM
PSDlongbox's Avatar
PSDlongbox
I am trying to push mine through this winter and then it is front end rebuild time in the spring. Not really looking forward to it at all...
Old Nov 15, 2013 | 07:43 PM
sg2004's Avatar
sg2004
well snow is coming and I DON"T want to get stuck with broken ujoints trying to plow snow. One side is really worn - getting a good vibration when turning from a parking spot or out of the driveway. was told this should fix this. think I'll change the diff fluid also. I'm sure it's original. Putting in Royal Purple like the rear.
Old Nov 15, 2013 | 07:51 PM
PSDlongbox's Avatar
PSDlongbox
yeah, mine are still tight, and I don't plow. I just know I am coming up on ball joints pretty and I have, for better or worse, a very "while I am in here" attitude..If I already have it torn apart, everything will get replaced. I think I am gonna throw a Spartan locker up front too.
Old Nov 15, 2013 | 08:27 PM
EXv10's Avatar
EXv10
Non-greasable have some advantages and you can buy them both ways.
Old Nov 15, 2013 | 08:34 PM
PSDlongbox's Avatar
PSDlongbox
and the advantages of non-greaseable would be?
trevorrules
Apr 17, 2017 09:37 AM
98SurplusExpy
Jul 21, 2011 09:13 PM
Wide Open Throttle
13
Dec 27, 2009 08:24 PM
THEDON117
Jul 14, 2008 07:09 PM
CounterMaker
Jul 29, 2007 12:22 AM
