Defrost problem- passenger side
Old Nov 13, 2013 | 05:29 PM
outsider347's Avatar
outsider347
New guy, first post
My new to me 93 F150 2WD 5L has a problem.
When in defrost mode, plenty of air center to the driver side
Very little defrost air volume, center to the pass side.
When I switch to vent mode, works as it should on both sides
I think that I have checked the obvious stuff, but hesitate to disassemble without a logical idea of what to do.
Thanks for any suggestions
Old Nov 14, 2013 | 06:10 AM
outsider347
anyone????
Old Nov 14, 2013 | 10:22 AM
rla2005's Avatar
rla2005
Perhaps the vacuum motor for defrost operation is broken, stuck of the vacuum line is faulty:
That diagram should be the same for your '93...
Old Nov 14, 2013 | 12:32 PM
outsider347
THANKS! for your response rla
Can you tell me where the vacuum motor is located under dash?
Does the top of the dash come off ?
Old Nov 14, 2013 | 01:53 PM
daddylee100's Avatar
daddylee100
I think somewhere a vacuum line is bad. For a long time when I had AC on and was going up a hill or any heavy acceleration the vents would shoot to defrost mode(default) when the vacuum was low. Traced it down to cracked line. AC in defrost position on 100* + day = no good. lol
Old Nov 14, 2013 | 04:16 PM
rla2005's Avatar
rla2005
Not sure where this vacuum motor is located but this might help: https://www.motorcraftservice.com/pu...1/SPMC2B21.HTM
Old Nov 15, 2013 | 12:23 PM
outsider347
here is what I found
I found the panel defrost vacc motor( with red tube attached) behind the ash tray assy.
I got my hand on the actuator lever to feel the operation.
Off position--lever retracted
Floor position--lever still retracted
Mix position--lever moves out a bit
Defrost pos-- lever moves all the way out...can't pull out manually any more travel
I think the vacuum operates the the motor as it should. Don't think its a vacc line problem
Something stuck somewhere?
Where?
Any suggestion appreciated
Old Nov 15, 2013 | 01:05 PM
dixie460's Avatar
dixie460
Ain't too sure what would cause this... if the vacuum motor is diverting air to the defrost duct then it shouldn't be leaking out anywhere. You sure something didn't fall down into the ducts on the pax side of the dash? The defrost duct is all one piece so unless it somehow split, the previous owner had his way with it, or something is blocking it, then the defrost air should be evenly distributed. You can see the defrost duct here along the top of the (upside down) dash... all one piece.
Old Nov 15, 2013 | 01:59 PM
outsider347
dixie460: tks for the pic.
3 From what I could feel, I thought it looked like that ...one piece!
I fished around inside the P side duct..nothing !!
How big a project to remove the heat/AC unit?
Old Nov 15, 2013 | 02:46 PM
dixie460's Avatar
dixie460
Not hard at all. Disconnect and remove the steering column... 4 bolts + 1 bolt on shaft. Disconnect the main cab electrical harnesses from the engine side of the firewall, then pop the bulkhead connectors free. Pull the parking brake pedal out, then the steering column support. The support is probably the hardest part, it requires some wiggling to sneak it past the dash. Then the dash itself has a bolt or two on each end, a couple underneath, and 4 or 5 across the top right by the defrost opening. Pull it towards you, reach behind and disconnect a few things like radio antenna cable and HVAC cables... pull dash out of truck. Then you'll see the entire hvac system hanging on the firewall. I have a pic. I'll try to post it...
Old Nov 16, 2013 | 07:09 AM
dixie460's Avatar
dixie460
Sorry... got distracted last night and forgot to come back and post the pic. HVAC box is on the right.
Old Nov 16, 2013 | 07:16 AM
Diesel_Brad's Avatar
Diesel_Brad
You have a blockage some where if you have the drivers side getting the air flow and the passenger side not
Old Nov 16, 2013 | 07:25 AM
outsider347
dixie460
Thanks for taking the time here
Much appreciated
Will probably be a few weeks before I have a chance to get back to it
Old Nov 16, 2013 | 08:50 AM
dixie460's Avatar
dixie460
dixie460
Much appreciated
You're welcome, hit my rep button if you want.
Like Brad said, it's gotta be a blockage somewhere, and as you can see by the pictures, it would have to be in the dash portion of the ductwork where it splits out to cover the entire windshield area.
wirebender
Jul 23, 2018 09:26 PM
pcdocta
43
Mar 19, 2017 04:16 PM
raleigho
Aug 5, 2006 05:28 PM
amber_da_2001
Jun 11, 2003 06:00 PM
MSG
1983 - 2012 Ranger & B-Series
May 12, 2003 07:30 PM
