Soft Brakes
Old Nov 13, 2013 | 10:24 AM
chefcharles's Avatar
chefcharles
Soft Brakes
I have a '72 F100 w/ 360fe. I am having to push the brake pedal a lot farther than I used to. I somewhat sudden, not progressive. The brakes are stock drums not power assisted. Should I add fluid and bleed or is it an adjustment. There is no noise or vibration. I noticed a slight smell on a downhill freeway exit when it took some pressure. They have always worked great and still do except I feel I am running out of pedal.
Any help and guidance would be much appreciated.
Old Nov 13, 2013 | 11:18 AM
Gembone's Avatar
Gembone
sounds like you might have a leaking wheel cylinder. Pull the drums and check for fluid.
This is also a good time to clean and adjust them. If the shoes are soaked in fluid then replace them along with the wheel cylinders.
Old Nov 13, 2013 | 02:32 PM
chefcharles
Should I see fluid under or around the problem wheel.
Old Nov 13, 2013 | 02:33 PM
Gettysburg150's Avatar
Gettysburg150
If its severe you can, if it just started leaking the drum and shoes do a good job of holding the fluid in there
Old Nov 13, 2013 | 04:41 PM
JEFFFAFA's Avatar
JEFFFAFA
Also check all three brake rubber hoses for cracks,leaking,weak sides,etc. There is one going to each front brake and the third is from the metal tube that runs down along the frame to the rear axle. There are metal lines that go from there to each wheel.
Old Nov 13, 2013 | 09:52 PM
chefcharles
When i checked the fluid just the front reservoir was low. The rear was fine.
Does this indicate front or back could be the issue.
Trying to out which end to jack up first
Old Nov 14, 2013 | 09:29 AM
Alex from GA's Avatar
Alex from GA
The small one is for the rear brakes and the large reservoir is for the fronts.
Old Nov 14, 2013 | 11:30 PM
orich's Avatar
orich
Sound like the master cyl. Find you can't find anything up front leaking..
orich
sncstealth
Mar 11, 2010 07:53 PM
flip1950
Oct 24, 2009 03:17 PM
63' f100
21
Jun 8, 2009 05:59 PM
Caleb H
48
Feb 9, 2009 05:02 PM
AMiller320
May 9, 2002 04:59 PM
