Help
Old Nov 13, 2013 | 10:06 AM
fluidp's Avatar
fluidp
Help
06 f350. Highway driving. Going up a slight hill. Icp. Good. Rip. good. Eot 185. Coolant temp 180. A loud pop/bang. And a whistling a sound. No codes. Motor running smooth. Hooked up AE. Power contribution. Good. Still have turbo boost. But sounds like a turbo with open intake
Old Nov 13, 2013 | 10:22 AM
npccpartsman's Avatar
npccpartsman
Check your CAC tubing and intercooler closely.
Old Nov 13, 2013 | 10:29 AM
big inch's Avatar
big inch
Yeah, check the side tanks on the intercooler.
Old Nov 13, 2013 | 12:00 PM
fluidp's Avatar
fluidp
Found the prob. Pipe to inter cooler came off. Under way again. Tks
Old Nov 13, 2013 | 12:10 PM
fluidp's Avatar
fluidp
First long road trip since I did a **** load of work. A little jumpy as I have a long road trip. Tks again
Old Nov 13, 2013 | 12:21 PM
big inch's Avatar
big inch
Good deal! I like a cheap fix.
Old Nov 13, 2013 | 12:44 PM
fluidp's Avatar
fluidp
What controls irp? Engine light on. P2290. Irp opening up to 85
Old Nov 13, 2013 | 12:47 PM
big inch's Avatar
big inch
Do you mean the IPR is going to 85% during normal driving? If so, that would normally indicate a leak in the high pressure oil system.
Is the P2290 the only code?
Old Nov 13, 2013 | 01:02 PM
fluidp's Avatar
fluidp
Yes still driving. With full throttle the icp won't go above 1800 and irp is at 85. At idle icp is 580. 2290 is the only code. 250 miles into a 1000 mile road trip. Motor seems to be running ok
TedHJ
May 30, 2016 10:36 PM
mike_pop
6.4L Power Stroke Diesel
Aug 10, 2013 09:37 PM
MikeyKazoo
Apr 11, 2011 01:08 PM
freedom76
Jan 30, 2009 04:24 AM
mind
16
Dec 8, 2008 08:09 PM
