Idler
Old Nov 12, 2013 | 08:35 PM
Vinford's Avatar
Vinford
Idler
2002 F-350 7.3
Had a front idler go 120 kms in the bush tonight, it was dark so I couldn't really tell what I need to fix it?
From what I could see there are 2 of them side by side?
Can I just replace one or are they a pair on the same bracket?
Any special tools or knowledge needed to change it out?
Old Nov 12, 2013 | 09:58 PM
Vinford's Avatar
Vinford
Anyone?......................
Old Nov 12, 2013 | 10:04 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Did it look like this? This is the belt tentioner.
One 13mm bolt and you are good to go.
mueckster's Avatar
mueckster
The 2 pulleys together are on the belt tensioner assembly. I replaced the whole assembly on mine. One bolt in the center and off it comes.
Old Nov 12, 2013 | 10:12 PM
Vinford's Avatar
Vinford
Thanks guys that's it .....................
Ill buy a new on in the morning and go get truck.
It was a little hard to stop with no brakes and no steering and pulling a Bobcat
Old Nov 12, 2013 | 10:24 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Remember, your emergency brake is completely independent of your service brakes (which should work even if you loose power steering/brakes). But should you lose service brakes all together you can still mash that emergency brake. It wont do much, but its better than nothing. Once speeds get down enough, you can down shift. locking out OD can also help.
Old Nov 12, 2013 | 10:31 PM
Vinford's Avatar
Vinford
Brakes worked somewhat but had to press very hartd to get it to slow down
Old Nov 13, 2013 | 07:24 PM
Vinford's Avatar
Vinford
Thanks for help it took 10 minutes to change tensioner and half hour to figure out how to put belt back on.
tiopet
Apr 2, 2013 01:20 PM
PowerLines
Jan 12, 2008 09:45 PM
skooch
Dec 6, 2007 07:34 PM
Wynn96
Jun 3, 2007 02:52 PM
