How do you replace ball joints on 1997 e350?
Old Nov 14, 2013 | 09:45 PM
blageurt's Avatar
blageurt
I have had 6 Vans so far.....You need the Funkadelic Special E-series tool to remove the lower ball joint....I bought the Ball Joint Kit @ NAPA...plus the Funkadelic tool ...Then I had it Professionally aligned and they corrected the camber et.etc.etc. ....... I have always used the Factory Manuals BUT .......I think the nut is 27 mm...but I would have to check...could be 32 mm also....
I usually torque it to 22-25 ft-lbs and then back it off 1/8 of a turn ( 45 * Radially ).......then spin Rotor and hand tighten to nearest hole on crown nut........ then install Cotter Pin....
Old Nov 14, 2013 | 10:44 PM
BombThreat's Avatar
BombThreat
Could you further explain this special tool for the ball joint? Or possibly provide a link to it? Thanks
Old Nov 15, 2013 | 12:31 AM
blageurt's Avatar
blageurt
http://www.summitracing.com/int/part...7825/overview/
And you will also need this .....http://www.summitracing.com/int/part...1550/overview/
Old Nov 15, 2013 | 05:21 AM
JWA's Avatar
JWA
Blageurt's idea about 27 or32mm sounds about right---certainly not a 2 7/8"!
I love the Ball Joint Remover Socket---for this type job it would be great to have. My guy didn't have anytime similar however his kit did have a selection of different diameter sleeves most common to ball joint servicing.
I think (and can be wrong) some parts retailers like AutoZone et al rent tools like the universal ball joint press. If this is just a one time job rental might be a better option, if its available in your area. Even so at $132 the linked kit isn't a budget killer.
van_a_knockin
21
May 2, 2014 07:27 PM
Bogeyman66
1997 - 2003 F150
Apr 23, 2013 11:06 PM
xltblt
Oct 26, 2011 07:23 PM
89ranger2.9
May 28, 2007 03:37 PM
RogerW
Sep 25, 2000 07:33 PM
