I am looking to do a camshaft in truck as I am digging into do the timing set. I talked with my teacher and he said that there can be problems with the heads and bottom end but did not say anymore then that. I want to know what I put at risk by caming. I also want to know what all might have to be changed in order to make the cam usable in my truck. The truck has 130k on it and the cam I am looking at is a 204/214 at 050. Thanks for the help
Instructions
Brand:Summit Racing
Manufacturer's Part Number:SUM-3500
Part Type:Camshafts
Product Line:Summit Racing® Camshafts
Summit Racing Part Number:SUM-3500
Cam Style:Hydraulic flat tappet
Basic Operating RPM Range:1,200-5,000
Intake Duration at 050 inch Lift:204
Exhaust Duration at 050 inch Lift:214
Duration at 050 inch Lift:204 int./214 exh.
Advertised Intake Duration:282
Advertised Exhaust Duration:292
Advertised Duration:282 int./292 exh.
Intake Valve Lift with Factory Rocker Arm Ratio:0.486 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio:0.512 in.
Valve Lift with Factory Rocker Arm Ratio:0.486 int./0.512 exh.
Lobe Separation (degrees):112
Computer-Controlled Compatible:No
Valve Springs Required:Yes
Camshaft Manufacturers Description:Smooth idle, excellent low-end torque. Works well in stock engines and towing applications.
Quantity:Sold individually.
That is all the specs that I am gave on line. Thanks for the quick reply.
The lift is a bit more than I expected, but not out of reason. The RPM range is slightly higher than I would have suggested as I like to have the range start at 900 or so, but 1200 isn't bad, and at least the top end is said to stop at 5k. And their statement of "Smooth idle, excellent low-end torque. Works well in stock engines and towing applications." is exactly what I would be looking for. Sounds good.
With a flat-tappet cam you absolutely HAVE TO change the lifters as well. Each lifter mates with the cam lobe and if you pull them at some point they absolutely MUST go back with the same lobe or they will fail in short order. The rocker arms should be fine, as should the push rods, although check them for being straight by rolling them on a flat table. And, you said you were doing the timing set - that's a must as well.
Or daily driver with automatic lol. I haven't seen snow in close to two years now.
That too. That's what mine was after I blew the motor before the current one. Now its just a beater at the moment. That's why I love my RV cam. Builds power über low. But it's dead by 4500.
