Snap on MT2500?
Old Nov 11, 2013 | 04:19 PM
Atc210's Avatar
Atc210
Snap on MT2500?
I got a free snap on MT 2500 and was wondering what cartridges and cables I need to read the codes on my 2002 Ex with the 7.3 diesel?
Old Nov 11, 2013 | 04:39 PM
Archion's Avatar
Archion
Veteran: Marine Corps
IIRC 2001 was the last produced full cartridge update. Beyond that you have to get the programmable cartridges and go find a Snap On man to program them for you, if they even will anymore. Support officially ended in 2009. Most have moved onto the Solis.
Old Nov 11, 2013 | 07:51 PM
Atc210's Avatar
Atc210
So, if I score some 2001 cartridges it should still read the codes and work on the 02 7.3 right? There were not a lot of changes in the 7.3 between 01 and 02 in the motor. Or should I just scrap it and stick with the scangauge for now?
Old Nov 11, 2013 | 08:40 PM
cameeks's Avatar
cameeks
There was changes in the electrical side I know of for pcm and fuse panel.
Old Nov 12, 2013 | 05:38 AM
Archion's Avatar
Archion
You can get generic OBDII codes, that's about it. There was a later global cartridge that did some canbus stuff, but you need the proper adapters for it. I have a 99 cartridge in mine and still use it to pull codes if needed. No diagnostics post 99. If you get the 01 cartridge and tell it you are working on an 01, it may let you pass...
Old Nov 12, 2013 | 06:33 AM
Atc210's Avatar
Atc210
Well, might be worth a try if I can find one cheap enough. Other wise I might just look into the AE software. Thanks for your help.
wavz
Jan 6, 2019 09:41 AM
Renagro Gibson
General Diesel Discussion
Apr 16, 2018 09:29 PM
troposcatter
Jan 26, 2017 08:21 PM
78fordman
Apr 25, 2015 10:08 PM
59203shop
Nov 4, 2014 07:33 PM
