throwin codes
Old Nov 10, 2013 | 09:40 PM
04badford's Avatar
04badford
I was hoping some of the other guys would have a take on this,what ever you do don't throw parts at it until we know for sure, Did you save any of the codes that were thrown we really need those to have a good Idea.
Old Nov 10, 2013 | 09:44 PM
Rusty Axlerod's Avatar
Rusty Axlerod
So you have a Check Engine Light and have pulled low voltage codes for all 8 cylinders?
Old Nov 10, 2013 | 09:45 PM
acidbzero's Avatar
acidbzero
It was p0261 and on for all 8 cylinders. It kept repeating on the obd.
Old Nov 10, 2013 | 09:46 PM
acidbzero's Avatar
acidbzero
Yes i have a check engine light and codes for all cylinders.
Old Nov 10, 2013 | 09:56 PM
Rusty Axlerod
Here's a few things to look at:
https://www.ford-trucks.com/forums/a...8&d=1289391592
Old Nov 10, 2013 | 10:11 PM
acidbzero's Avatar
acidbzero
I take it i need some special test equipment. Sounds like i might need to take it into the shop. I ordered a bluetooth logger/obd. It sounds like that's what I need.
Old Nov 10, 2013 | 10:17 PM
04badford's Avatar
04badford
most of us use a Scan Gauge II from Auto zone, around 160.00 you can get it cheeper on line ,theres dash boss and other types but I don't really know to much about them , the Gauge is a must to a healthy 6.0 to monitor EOT ECT and all the sensers , live data, boost, temps so on
Old Nov 10, 2013 | 10:27 PM
acidbzero's Avatar
acidbzero
In order to rule if its a ficm problem, I'm going to need a scan gauge? Or is there a way to narrow it down without it.
Old Nov 10, 2013 | 11:22 PM
BLADE35's Avatar
BLADE35
Originally Posted by acidbzero
The lp was 12.5 and the vp was 13.6.
How are you Taking these Readings??
The Lodgic Power Worries me seen a couple Bad Relays but other then that Your Inline for a New FICM
Ed at www.ficmrepair.com is the Man to do this for ya He can Also sell ya a DC Power High Output alternator
Our OEM Alternators are Under powered
so All of Those Folks that take Precaughtionary steps here Get there electronics and Batterys to Last a lot Longer
Old Nov 10, 2013 | 11:43 PM
acidbzero's Avatar
acidbzero
Maybe I need to double check all of these. I think there may be a miscommunication.
Old Nov 11, 2013 | 12:06 AM
acidbzero's Avatar
acidbzero
As for diagnostics I only have a multimeter. Crap. I think i misread a few posts. I feel like im getting confused.
Old Nov 11, 2013 | 12:39 AM
BLADE35's Avatar
BLADE35
Its OK No worries
we can backtrack and Touch anything you are hesitant on You will understand Im shure
Best thing Here is to get a ScanGaugeII
www.scangauge.com
They do sell at Autozone localy
Just have a Cheap Code reader?? Can you Post Both Codes Please
You can test a lot with a Multimeter but there is No room for Error you kinda need wire diagrams ect.. to make shure your testing the right wires
You installed New batterys Right??
But once you get a Gauge we can check it Over and there is Other gauges out there ScanGauge is Fast to get is ALL and does a Decent Job if you have more Time there are Other Options out there Like DashBoss
Here is DASHBOSS its Better then SGII But either one will work for this
http://www.dashboss.com/
But keep in mind when Someone comes here and says I have ALL 8 Injector Low Code that is about a 95% chance FICM is Bad But I would like to see a Couple other readings First if it were Me!!
Old Nov 11, 2013 | 06:39 AM
  #28
npccpartsman's Avatar
npccpartsman
If you have low circuit codes for all 8 cylinders you have a failed FICM.
Old Nov 11, 2013 | 07:08 AM
  #29
Rusty Axlerod
If you read through the TSB I posted the link to, it basically says to check the charging system then verify voltages (with a meter) on specific pins in the FICM plug and if all that is ok, repair/replace FICM. I think a Scangauge/DashBoss or similar is a great idea but I don't know anything you can do with one to diagnose issues on the logic side of the FICM except see if it is syncing.
Old Nov 11, 2013 | 08:02 AM
  #30
acidbzero's Avatar
acidbzero
I read the tsb. I'll have to check it out today when I tear it apart. Today is a holiday so maybe not.
Happy Veterans Day to any of yall and myself.
I think the ficm replacement is looking to be right. I would to double check because I would be pretty upset if I ordered it and it kept throwing codes.
It sounds like everyone agrees that it's the ficm.
