Heater core
Old Nov 28, 2013 | 01:44 AM
warren561's Avatar
warren561
Originally Posted by Super Mech
Make sure you don't have any voltage in your cooling system, Fords are known for that, leading to heater core failure.
So, how does one address that issue? Attach a ground wire (somehow) to the heater core?
Old Nov 28, 2013 | 12:39 PM
turnkyle's Avatar
turnkyle
I would like to know how you test for and correct this as well.
Old Nov 28, 2013 | 05:44 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Use a voltmeter between the coolant (only) and battery negative terminal.
Anything above 1/10th of a volt is cause for concern.
Brass is less affected than aluminum (noblity scale)
I would suggest system grounding anywhere BUT the heater core, as this will cause more electron flow through it to ground.
Check all grounding straps.
Check with the battery disconnected from coolant to block, frame and chassis ground.
If you have voltage with the battery disconnected your coolant has become the acidic electrolyte.
Flush and change it. Retest the system.
Old Nov 28, 2013 | 09:10 PM
warren561's Avatar
warren561
Is there a handy list anywhere of where all the grounding straps are located?
So this confuses me. If I disconnect the battery, but I read a voltage between the block and the heater core inlet/outlet, that means that my coolant is acidic and acting as an electrolyte?
Old Nov 28, 2013 | 09:24 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
1) Grounds.
There is no way for me or anyone to list what goes where for all the variety of trucks covered here.
For my truck offhand...
Battery to frame to block.
Strap from engine to firewall.
Strap from cab pinch weld to cab support below drivers feet.
2) No
If you remove the battery from the equation and there is still voltage potential between -the coolant - and any ground you have a battery that IS your cooling system.
Regardless, the acid will eat your aluminum heater core from the inside out.
Litmus test will show this.
But better preventative maintenance is obviously indicated.
Old Nov 29, 2013 | 02:30 AM
Super Mech's Avatar
Super Mech
ArdWrknTrk, that was very well said!
Old Nov 29, 2013 | 09:32 PM
2500ak's Avatar
2500ak
I swapped out the aluminum core I had for one that fits. It seems to work, but not nearly as well as the old one. It heats up the cab, but the brass core got the air so hot it would burn you if you held your hands to the vents.
I think I might have to have the old one fixed. That or find a NOS one.
Old Nov 29, 2013 | 10:03 PM
kermmydog's Avatar
kermmydog
The last one I bought was aluminum. One way they say to extend life is to use a HOAT anti freeze. Something like Dexcool. It is suppose to cut down on the electrolysis with the aluminum, but yet the two Dexcool GMs I had needed heater cores long before any Ford. Maybe Ford has a version of coolant for their new aluminum cars & trucks. HOAT is recommended for Jeep, Dodge, Ram. Yet I run the green in my 99 Ram that is what came in it.
So as stated very glad Ford made them so easy to change.
LOVEMYLABXS
Aug 31, 2014 06:35 AM
19fifty4
Nov 29, 2009 06:20 PM
adams.construction
Feb 20, 2009 12:53 PM
SilverSport
Dec 18, 2006 11:24 AM
Phillip Guidry
Sep 20, 2004 12:39 PM
