Lowering truck
Old Dec 16, 2013 | 02:07 PM
  #46
Rich56's Avatar
Rich56
Which control arms did you purchase, if they are the same length as the stock ones your tire is going the be right against your fender. If they are a narrowed set you will have to also buy the uppers.
DJMs 3" drop, no need for spindles or removing anything other than the lower arm.
Same measurements, Purchased thinner rims and tires, hope to lose 1 1/2" there, if not, sell em and they make custom offsets anything I want, just double the price, we will see.
Old Dec 16, 2013 | 03:32 PM
  #47
56panelford's Avatar
56panelford
You did see where I mentioned I purchased narrowed control arms
Old Dec 16, 2013 | 04:36 PM
  #48
Rich56's Avatar
Rich56
Yes, Thanks.
Old Dec 17, 2013 | 03:08 AM
  #49
56 Big Window's Avatar
56 Big Window
The drawback with 3" dropped lower control arms are, the spring pocket will hang 3" below the actual control arm, possibly below the "scrub line" with 15" wheels and the static angle of the upper control changes severely, causing a change in the "camber curve" of the front end's geometry. It can also lead to upper ball joint bind and grease boot failure.
I had the option of 3" control arms on my S-10, but chose 2" spindles & 1" springs.
Old Dec 17, 2013 | 06:23 AM
  #50
Rich56's Avatar
Rich56
Friend has them and has had no issues, 18" wheels going on, drop spindles will also lower the control arm down as well and the wheel isn't centered between the arms, front riding now on lower part of wheel.
Can always install all new everything down the road if any issues.$$$
Old Dec 17, 2013 | 10:22 PM
  #51
56 Big Window
Not trying to be argumentative or critical, my friend, just sharing my knowledge of lowering GM truck front suspensions. You're right, with 18's you'll have no scrub line issues, and glad to know your friend has been running them with no issues.
Old Dec 18, 2013 | 07:56 AM
  #52
56panelford
I'm curious as to what rim size and back spacing you are using up front. I had to narrow the tracking 4" and running 15x6" with 3 1/2" back spacing.
Old Dec 18, 2013 | 09:33 AM
  #53
Rich56's Avatar
Rich56
18x7... 4.25 backspace, 215/45r18 tires
Old Dec 18, 2013 | 11:23 AM
  #54
56panelford
Please let me know how it works out. Before I purchased the modular spindles my tires were touching the fenders, the new spindles brought them in 1 1/8" but rubbed when turned lock to lock which prompted me in purchasing the narrowed control arms and went with smaller diameter tires (27" tall) .
Old Dec 18, 2013 | 01:01 PM
  #55
Rich56's Avatar
Rich56
Will do, tires won't be here till hopefully sometime next week, have everything else and should be warm enough to get at it this week.
It's going to be close, and with the new springs not sure exactly where it will sit as far as height goes, but should be close.
My tires are 25.6" in height and 8.4 section width.
Old Dec 18, 2013 | 06:54 PM
  #56
edsf100's Avatar
edsf100
Nice looking truck. mid-fifties catalog has a section on different lowering methods.
Old Jan 11, 2014 | 12:12 PM
  #57
avf100's Avatar
avf100
Did you get this done yet? And any pics ?
thanks
Old Jan 11, 2014 | 03:10 PM
  #58
Rich56's Avatar
Rich56
Finished the front, wheels came in wrong finish, put them on to see fit and drive around the block, rear not done yet, waiting for right rims to come in so I can get it to the spring guy. These are polished, ordered chrome. Sits nice now and front tire clears fender.
Old Jan 11, 2014 | 03:39 PM
  #59
Schuyles's Avatar
Schuyles
Lookin good!
Old Jan 11, 2014 | 10:03 PM
  #60
56 Big Window
Lookin REAL GOOD! What color Red is that?
