Lowering truck
Lowering truck
How are these trucks lowered so much, my question is, if I lower mine 6" the rear will hit the bed.
Hoping to lower at least 3" front and rear with larger tires, just wondering if 3" of travel is enough between rear and bed.
Here's how it sits now, replacing all the wheels and rims with probably 17" rims and less of an offset, the rear tires will hit the fenders if lowered now, DEEP dish no offset.
15" rims on now.
Better shot here of the way it sticks out a 1/2 to 3/4" with offset now. Rear Tire.
15" rims on now.
Tires measure at 12" back 10" front, probably correct on that rim size, probably going with a slighter thinner tire front and rear, plenty of room there anyway, still have 3" from back of rear tire to bed and leaf.
Lose 2" of offset and good to go.
Just wondering about how these trucks are slammed on the ground and rear doesn't hit bed, unless raised.
Thank You,
Was told a late 80s chevy pick up, looks it up front, heavy duty.
Will take it to my spring guy and see if stiffer leafs will ride fine with 3" of clearance.
Won't be loading it up with broken concrete anytime soon.
Hey Rich, is that garage in the background yours? Been by there a few times with a buddy of mine who lives nearby in Manorville. He's got a '62 vette, '62 Imapla SS, and a nice black '57 T-bird. Been trying to talk him into an old truck. He's thought about a '56 F-100.
Watching the answers to your question as I'm thinking of lowering my '52 maybe 2-3" in front and an inch or so in back. Not sure the best way or how much you can drop the front before steering and hitting become an issue. It's a ways away for me, yet.
Nice looking truck. Could you tell us a little more about how you lowered it and what modifications, if any, you had to do to make it work?
Thanks! The front of the truck has a Ford LTD front clip.The rear is a 1972 Ford Torino 9 inch.
I had the springs flipped to the bottom of the axle. While they had the truck they cut the front coil springs to even it out.
After I got it back I did not like the ride with the cut springs so I changed them myself.
I ordered brand new lowering coil springs from Eaton Spring. They were very good working with me to get me the spring I needed. It was a little difficult because I had to order a spring for a 1970 LTD. I knew the original springs was about 3 inches too high but the best they would commit to was 2 inches lower. As it turned out I got 2 maybe just a little more than 2 but it was enough - after all I need it to be drivable. It drives really smooth with the new springs... like an LTD! (sort of)
The rear had air shocks before but after the flip they were too long (they bottomed out) so replaced them with shorter air shocks. I put air shocks back in because it is not notched and I could always pick it up if needed. Although, I still may have to notch it someday. So far I have not had a problem but the air shocks do limit the travel a little.
The wheels are 2005 Mustang - needed 1" spacers for the front and 1.5" for the back because of the offset (they are 18 X 8.5). Worked out well because I needed to change the bolt pattern anyway. The LTD and other 70's full size fords were 5.5 the wheels are 4.5 (114.3).
Tires:
Rear- 245 60 18
Front- 235 50 18
Tires:
Rear- 245 60 18
Front- 235 50 18
Tires:
Rear- 245 60 18
Front- 235 50 18
Tires:
Rear- 245 60 18
Front- 235 50 18
Very nice truck, I have the same wheels waiting in the wings for another truck project. Can I ask where you got your wheel adapters and have you driven much with them? I also need adapters but am leery of the ebay specials, I dont want to lose a wheel after hitting a pothole or a burnout
Do you know how much clearance in inches you have between the rear axle and the frame rail and have you had any bottoming out issues? I should be around 3" with mine and am considering if I should C notch the frame or not. Thanks!
