Eddy Myrtle
The cab bushings look fine to me. I didn't change them over when I did my body swap, they're pretty durable. Sorry to hear about the paint shop, I've heard more horror stories about them then I have good ones. Just adds another reason to why I'll never repaint any of my rigs.
You'll get her back and going soon enough!
On the cab bushings I would say don't worry and use them. I don't think mine looked that good and I reused them.
Only bushings I did replace was the front pivot bushings, the radius arm bushings were replaced with poly on 1 of the 2 trucks and I used them.
Rear rubber spring bushings looked good so I reused them. If I was to replace them I would only replace the front one as the rear bushing are just along for the ride.
Dave ----
I think it might actually look worse though, really not liking the ghetto look! I wanted something which looked like it belonged in the 80's, but this is all I could get my hands on here... Now I'm stuck in the 90's!!
I put some tape around the edges to stop the porous stuff from covering the speaker! I'm not sure if the spongey stuff was suppose to minimise vibration or something, but it definitely wasn't meant to last 30 years!
I think I'll probably get a dash pad like I've seen some guys use. It's a shame 'cause the rest of my dash looks great. Oh well, this will do for the time being.
Well the dash in my 82 was cracked all over by the speaker so I pulled the speaker grill out, put it on top of the dash and covered the whole dash with dash carpet with one from Ebay
I'm planning on just replacing the seals and gaskets on the transmission. I've found a kit on Bronco Graveyard for $20, any other suggestions? The transfer case had no leaks when I removed it and since I don't plan on doing any serious off-roading, I'm leaving that as is.
Any advice or tips on my immediate plans?
Then I got the frame outside to give it a good clean.
And then I started at the back with the painting... The u-bolts were a right nightmare. I got the air impact wrench from HF and was bitterly disappointed when it proved about as useful as a paperweight! So much for 950ft-lbs! The cheap electric one I already had did a better job. At least it broke the nuts loose, but that's all it would do, from there I had to use the breaker bar. I actually bent one of the u-bolts... I returned the air impact wrench and got the more expensive electric one, so far it hasn't really been tested. (Might return that one too as I'm done with disassembly now)
I left the diff alone for now. I did not want to rebuild it myself and I did not want to rely on anyone either. Without knowing what I'm looking at, it looks OK...
I did replace the axle bearings and seals. I'll also have to replace the pinion seal, the current one leaked badly. I finished the painting, replaced the brake hardware and reassembled everything. New bushings on the leaf springs too. I managed to remove the rear ones myself, but the fronts I had a guy burn and hammer them out. Instead of paying him to do the shackles too, I just bought new ones.
I picked up my 'new' engine a couple of weeks ago. That project snowballed as well and ended up being more rebuild than clean... At least the guy was professional and did everything in a timely manner. It's got a new camshaft and lifters. New pistons on the old rods. New timing gears. Bored cylinders. The head was just reworked.
Anyway, so the engine is waiting while I proceed to the front of the truck. Disassembled that last week. I haven't uploaded the end result pictures yet, but most of you can imagine what I struggled with...
The spindle did come off rather easy once I had the right tool for the job... https://www.napaonline.com/en/p/BK_7769181
The ball joints were a different story. For one, the cotter pin broke off on the driver's side, while stuck inside. Also, both nuts on the driver's side were a different size from the passenger's side?! The passenger side was a breeze with a 3/4" socket set's breaker bar. The driver's side, less so. On top I managed to hammer a socket on(after going at the stuck cotter pin with a punch) and then with the help of a 3ft pipe over that breaker bar got it loose. I had to buy a 28mm socket for the lower nut, but got that done too. Then it was just a case of hammering the **** out of the joints to get the knuckle off. Now I still have to remove the joints from the knuckle. Still contemplating buying a press or taking it somewhere...
