5.8L emissions trouble
Old Nov 9, 2013 | 01:48 PM
Blk007's Avatar
Blk007
I have a 91 f250 with the 5.8L. On the back of the engine is an air crossover pipe that is broken. This pipe connects to both heads and attaches to an air check valve in the middle which is also broken off. I bought the truck like this and because of the firewall it is extremely hard to reach. Anyone know if I can either plug this system or do I really need it?
Old Nov 10, 2013 | 03:43 AM
glruff's Avatar
glruff
FTE Leadership Emeritus
Moved from Picture thread.
Welcome to FTE!
Old Nov 10, 2013 | 12:01 PM
baddad457's Avatar
baddad457
If your state doesn't require it to be present and functioning for vehicle inspections, you can remove it and plug the holes in the ends of the heads. You can do that by screwing in short 5/8"NC bolts (the holes are threaded) or as I saw recently, just flip the ends of the tube and bolt it back in place to cover the holes. You may get a check engine light from doing this, really not sure though. My 96 E150's 351 doesn't have any of the Thermactor system, never did.
Old Nov 10, 2013 | 12:14 PM
Blk007's Avatar
Blk007
Thanks for the info. Much appreciated.
Old Nov 23, 2013 | 09:35 PM
gman97005's Avatar
gman97005
simply remove the crossover and turn it around backwards then bolt it back on, problem solved..
Blk007
15
Nov 19, 2013 02:00 PM
hozee4
Jul 20, 2013 05:23 PM
floridamudder88
1978 - 1996 Big Bronco
19
Aug 29, 2010 11:42 PM
edcp
Apr 30, 2004 02:01 AM
Xwarrior86
Nov 21, 2002 10:46 AM
