engine swap help
Old Nov 9, 2013 | 05:54 PM
buff64's Avatar
buff64
engine swap help
I've been building a 69 f100 from the ground up and have a 400 engine tore down to rebuild but my brother just got a 70s' 440 and trans with 23,000 miles that runs. He said if I can make it fit I can have it. Now I know what a lot of you will yell but this can save me a lot of money and get me on the road . The question is how hard would it be to do this and what would it involve? Some one please give me some help and not to much about the trader part.
Old Nov 9, 2013 | 06:16 PM
HIO Silver's Avatar
HIO Silver
You'd better know how to fabricate and engineer your way through it. Otherwise, this "good deal" is a curse in disguise. In the end, it's gonna cost you more in the long run to adapt that 440.
Good luck.
Old Nov 9, 2013 | 06:29 PM
51MHF5's Avatar
51MHF5
What he said...why don't you just sell the 440 setup to finance your 400 build?
Old Nov 9, 2013 | 07:26 PM
buff64's Avatar
buff64
Thanks HIO Silver and 51MHFS for the quick response. That's what I was wanting to know so I will sell the engine and finish my own. Thank you for your answers.
Old Nov 9, 2013 | 08:16 PM
orich's Avatar
orich
Well when I was very young and having welder your friends with one it was now big deal to trans plant a other engine into a sleeper. As my brother had a 39 chevy with a big V8 flat head Caddy motor.
One you look at the pan like what will it clear or hit.
Then the exh outlets on the exh manifolds like will it hit or will you need to feb up headers from a head kit.
Then how will you fab up and build the motor mounts for your mopar motor.
Then a few hundred buck for a drive line. And then the cooling system maybe a custom radiator another few hundred bucks.
But if you have a lot of good friends that could help out with some of custom fabrication work then go for it.
Also like stated above since your asking here you don't have a clue
of how to go about this engine swap for sizing it all up in your mines eye to go for it..
Not a lot of Mopar lovers here since this site is about Ford Trks and but it's your truck and you can stuff any motor you want into a ford vehicle..
Plus what kind of resale value would this at to your vehicle with that mopar motor in it.. my 2cents orich
Old Nov 10, 2013 | 06:15 AM
jowilker's Avatar
jowilker
buff, Do you have a tranny (bell) to use with the 400 because your truck didn't come with a 400.
Looks like challenges ahead, choose wisely.
John
Old Nov 10, 2013 | 07:39 AM
BigBlockMan's Avatar
BigBlockMan
Sounds like you need a Dodge truck, but even then you'll have to make it fit.
Old Nov 10, 2013 | 09:33 AM
MIKES 68 F100's Avatar
MIKES 68 F100
+1 SELL THE MOPAR ENGINE
Old Nov 11, 2013 | 12:04 AM
dagomachining's Avatar
dagomachining
ditch the 400 and the 440, stick a 557 bbf , and a c-6 behind that, shorten the driveshaft, get some headers for a 74. you'll never look back other than to check if that rice burner is still behind you. or chevy or dodge.
Old Nov 11, 2013 | 03:17 PM
JEFFFAFA's Avatar
JEFFFAFA
Me personally I'd sell the Mopar to buy Cylinder heads and higher compression pistons for the 400. But as far as the 440 goes, Pincheweddo has a 67 that HAD a 440 in it. Check out his thread titled 1967 F100 Resurrection. Or PM him. He put a Ford motor in his so maybe he can sell you everything to stick that 440 in yours.
Davon3598
Engine Swaps
Nov 9, 2018 07:44 PM
Matt1966
Jun 17, 2017 10:35 AM
TheATeam
Dec 6, 2014 01:36 AM
cpetersen
Feb 12, 2011 07:53 PM
holland60
Jan 23, 2011 06:14 AM
