Cleaning out the cowl
Old Nov 8, 2013 | 02:17 PM
CropDusterMan's Avatar
CropDusterMan
Hi Wolf,
I took a 1 inch piece of PVC and added a connector to it to go to 1.5 inch and then jammed that into the end on my
shopvac...I heated up the 1 inch pvc to create a curve to it, then snaked that in through the plug holes in the firewall...
worked like a charm. Also, I removed the vents inside and snaked it up and down to the bottom...you'll likely encounter
some leaves and crud-mine had about an inch of dry dirt in the bottom!
Best,
Jason
Old Nov 8, 2013 | 04:00 PM
rogue40's Avatar
rogue40
Originally Posted by Wolfracing
The first time we opened those vents at speed we got most of the leaves from down low blown at us. LOL.
I got a mouse up my pant leg.
Old Nov 8, 2013 | 04:27 PM
TA455HO's Avatar
TA455HO
Lead Gopher
"There's a snake in my boots"
I went to look at that Ranger down in Auburn and opened up the drivers vent with the owner standing there and pulled at least three handfuls of muck out of there. It's not going to last long like that if he doesn't tend to it.
Old Nov 11, 2013 | 09:42 PM
Jeff64F100CrewCab's Avatar
Jeff64F100CrewCab
For prevention head to a local sign shop and ask for some leftover magnetic sign material. I got several pieces to place over the vents here in pine tree country. Those things aim for the vent openings on purpose! Water can get through, but not the needles. Even when you forget to remove them for a drive, they don't fly off, but no air flow.
1TonBasecamp
35
Dec 3, 2024 10:53 AM
armyaviation
Feb 3, 2017 12:12 PM
emgee
Sep 15, 2013 08:08 PM
tempest411
Jul 4, 2013 01:04 AM
Kustomfiend
Jun 4, 2009 11:42 PM
