Best cleanup for vent?
Old Sep 14, 2013 | 07:51 PM
emgee's Avatar
emgee
I've replaced the slotted cowl with one from a Bricknose and I've removed the slider vents from the kick panels and dredged out as much composted leaf material as I can. I can stir around what's left so it dries and then vacuum out the rest. Is it a good idea to hose the vents out with water to thoroughly clean them?
Old Sep 14, 2013 | 08:04 PM
Franklin2's Avatar
Franklin2
It should not hurt anything. Water is going to enter in there on a regular basis through your vent holes at the wiper area. There should be drains down at the lowest point on each side at the bottom where all the dirt was. Make sure the water flows out these holes.
Old Sep 15, 2013 | 08:08 PM
emgee's Avatar
emgee
OK that sounds good. I can see a funnel-shaped drain from that area now that I've separated the plastic wheel housing from the fender.
1TonBasecamp
35
Dec 3, 2024 10:53 AM
Wolfracing
18
Nov 11, 2013 09:42 PM
tempest411
Jul 4, 2013 01:04 AM
rvx290
2004 - 2008 F150
Aug 19, 2010 04:17 AM
"Beemer Nut"
Dec 22, 2005 02:19 PM
