Sponsored by: Real Truck
issues with 2001 v10
Old Nov 6, 2013 | 09:27 PM
chirdak66's Avatar
chirdak66
Just bought this truck, with some issues know, and some that i have just realized. One of the things that worries me, is a constant ticking, from idle to shut off. Is it just a misfire? I have also seen that maybe its a broken exhust manifold. Any other ideas? And the power mirrors do not work, looking at some other forums, they say that the same fuze that is connected to power mirrors, is connected to the light in the glove box. Is that true? And if so, the light is working fine, but the mirrors will not work. I have a few other issues but nothing major.
Old Nov 6, 2013 | 09:54 PM
redford's Avatar
redford
FTE Leadership Emeritus
Hello chirdak66 and welcome to FTE.
My first guess for the ticking would be an exhaust leak due to an exhaust manifold stud failure.
As for the power mirrors, fuse #4 is for Glove Box Lamp, Map Lamps, Power
Mirrors, Underhood Lamp.
Old Nov 6, 2013 | 09:59 PM
chirdak66's Avatar
chirdak66
Ya the light in the glove box is working fine, and from what i have read the exhust manifold is a rather common problem, with these trucks. What do i have to do to fix it?
Old Nov 6, 2013 | 10:08 PM
redford's Avatar
redford
Replace the exhaust manifold studs, if that is the issue. A visual inspection will tell you pretty quickly if they are the problem. Look for missing studs, corrosion and such.
F250_
Jul 11, 2012 09:00 AM
RM2738
6.4L Power Stroke Diesel
Jun 9, 2012 09:19 AM
tones40
Electrical Systems/Wiring
Nov 20, 2003 09:01 AM
qwertlaw
Aug 3, 2001 03:36 PM
