Injector torque??
Old Nov 6, 2013 | 05:59 PM
fluidp's Avatar
fluidp
Injector torque??
Does anyone have the injector torque in in/lbs Tks
Old Nov 6, 2013 | 06:10 PM
BLADE35's Avatar
BLADE35
I google a Converter on the internet
Online Conversion - Force Conversion
Old Nov 6, 2013 | 06:19 PM
bismic's Avatar
bismic
ft-lbs times 12 equals in-lbs
28 x 12 = 336 inch-pounds
As an fyi, a person on another forum stated that Ford has revised the torque to 31 ft-lbs. He stated that the new spec was included in an instruction sheet that came with a Ford "Remanned" injector. I wonder if anyone else has seen this change (or heard of it)? EDIT - it is confirmed that Ford did NOT issue any such document!
Old Nov 6, 2013 | 06:53 PM
fluidp's Avatar
fluidp
Thank guys
Old Nov 6, 2013 | 11:37 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
Ford's spec is still 26 ft.lbs for 04.5+, but the aftermarket reman recommendation has been 31 ft.lbs for well over a year now.
Josh
Old Nov 6, 2013 | 11:44 PM
bismic's Avatar
bismic
Many Ford Techs have been recommending 28 ft-lbs for years for the T45 hold-downs (late/commonized LATE '06 and up, not '04.5 and up). IMO that is (EDIT) acceptable, but may not be all that necessary. (EDIT) Some techs are recommending the 28 ft-lbs for the T40 hold downs, and IMO that is unwise.
EDIT - there is NO FORD documentation of a higher torque spec. 26 ft-lbs for post Jan 11, 2006 (commonization w/ T45 torx for hold-downs), and 24 ft-lbs prior to that (T40 hold-downs). Can yo bump these up a little and be ok? Probably, but I don't want to cause anyone to crack their head(s).
Old Nov 7, 2013 | 12:17 AM
Bullitt390's Avatar
Bullitt390
Many Ford Techs have been recommending 28 ft-lbs for years. IMO that is wise.
I would still like to know if there is FORD documentation of a higher spec. The last I recall seeing is 26 ft-lbs for post Jan 11, 2006 (commonization w/ T45 torx for hold-downs), and 24 ft-lbs prior to that (T40 hold-downs).
There isn't... just some of the aftermarket rebuilders recommending 31 ft.lbs.
26-28 ft.lbs is plenty.
Josh
Old Nov 7, 2013 | 03:35 AM
brickie's Avatar
brickie
Twenty four to 31.. My luck Ide hear snap.lol Mine are at 26.
Old Nov 7, 2013 | 06:18 AM
npccpartsman's Avatar
npccpartsman
Casserly told me he recommends 28 ft/lbs but he also puts 7.3 crush washers on his injectors and always has because they're a tweak heavier (or used to be). I've never had an issue (knock on wood).
Old Nov 7, 2013 | 01:12 PM
fluidp's Avatar
fluidp
ive finished the drivers side injectors set them at 28 will do the passenger side oned thisafternoon
starmilt
Apr 14, 2023 01:53 PM
BuddyBarnes
Jan 14, 2017 04:30 PM
cowmilker08
13
Jul 19, 2013 11:45 AM
2000f-250psd
Mar 20, 2011 01:11 PM
mhenneboehle
Apr 2, 2010 09:38 PM
