Injector problem & Thanks
Old Nov 3, 2013 | 09:26 PM
Brownie12's Avatar
Brownie12
Gidday ,
Package arrived from Riffraf to New Zealand so have had head down b up changing glow plugs , retorquing inj & rockers , just sorting what coin to use as plug was not all way in . While I was in there I see one injector is different from the rest ????? X 7 are AP 63803 AD with a cream plug X1 is a AP 63804 AE with a blue plug ....... do I need to worry about this ???
Also a Big thankyou to all you guys as I have been able to do all this work , from diagnosis to repair with links and posts on this site , it has saved me heaps
Brownie
Old Nov 3, 2013 | 09:35 PM
Shake-N-Bake's Avatar
Shake-N-Bake
The AE injector with the blue plug goes in the #8 location. (left rear)
Old Nov 3, 2013 | 09:51 PM
Tugly's Avatar
Tugly
The AE belongs in number 8 cylinder (passenger side on your side of the pond, closest to the firewall). It was Ford's attempt at reducing cackle because #8 is at the end of the line for fuel.
NZ is a fantastic country. I spent some time going from Auckland, down to Hawke's Bay (saw the thermal springs at Wairakei), then up to the Bay of Islands... where we rented a sail boat and hung out with dolphins for a few days. I saw some fantastic scenery while I was there and the people are as friendly as one could wish for. I couldn't get into the beet burger, but you guys are serious about coffee... and that works for me.
I also learned that when the windshield wipers go on without an obvious reason, the driver is used to driving on the other side of the car... not that it happened to me.
Old Nov 3, 2013 | 10:15 PM
Brownie12's Avatar
Brownie12
What harm can it do
Thanks for quick replies guys , # 8 aaaaaaa ........ at the moment it is in #2 Left hand side , front cylinder , been there for a while cos truck has been part of the family for 2 years , just never been under VC . What difference will it make
We are busy seeing NZ at the moment as F truck tows the hut for me and the bride , clean the windows, know the feeling , do it every time I drive a Jappa Will have to learn how to record a session on the AE so ya can tell me if all is good with the 7.3 . Have to go to AE school and do some research first
Brownie
Old Nov 4, 2013 | 06:33 PM
Shake-N-Bake
Originally Posted by Brownie12
Thanks for quick replies guys , # 8 aaaaaaa ........ at the moment it is in #2 Left hand side , front cylinder , been there for a while cos truck has been part of the family for 2 years , just never been under VC . What difference will it make ...
It may not make any difference at all.
The AE has a slightly shorter intensifier piston which makes it begin the prime shot a bit sooner than the rest. It's such a small difference that it's hard to believe Ford thought it would have any benefit...yet they dropped them in some engines anyway.
Unless you know the history of your truck, then I would leave that injector in the #2 spot and keep trucking along. It's entirely possible the intensifier piston has been changed during a previous rebuilt or replacement anyway. The solenoid itself is exactly the same as an AD pack so nobody really knows what you have in there except for perhaps the previous owner (and even he/she may be clueless as well...).
Old Nov 4, 2013 | 07:58 PM
Brownie12's Avatar
Brownie12
40 cents worth
Gidday ,
Is all up and go again , took a couple of nz 20Cent coins to do the mod , decided to leave injector where it is been happy for a while , just fired her up , started much quicker with new GP's ,Changed all filters and oil in engine, rear diff, fitted new ICP which has stopped the hunting and appears to have given it a few more horses, took for a run down the road and all is good Thanks for the help
Brownie
egregg57
Sep 15, 2014 04:27 PM
alienbogey
22
Sep 6, 2013 02:08 PM
cutlass
33
Jul 17, 2013 01:41 PM
Mr-Pipeline
Modular V10 (6.8l)
Nov 19, 2010 07:04 PM
wahusker
May 24, 2009 10:49 AM
