P0107
Old Nov 3, 2013 | 04:07 PM
wameyer's Avatar
wameyer
P0107
First I have searched and im having trouble locating the sensor. I have a '99 f250 and F350. The 250 through the P0107 code and Ive read that the PCM could be the issue so I swapped it out with the dually. I am still throwing the same code, so I swapped out the MAP and I swapped out the both gas pedals( thought thats where a sensor was) Cant find the sensor that supposed to be under the dash on the right side of the steering column. The dually is not throwing any codes even after I swapped out the PCM and MAP. Any help would be appreciated. Thank you.
Old Nov 3, 2013 | 04:56 PM
cleatus12r's Avatar
cleatus12r
Butt-Head
P0107 is for the barometric pressure sensor.
Early build 1999 vehicles have the sensor located behind the hush panel underneath the steering wheel. Late build 1999 vehicles up to 2003 have the sensor located inside the PCM.
Hypothetically speaking, if you swapped the PCM from the F350 (which may be an early 1999), you'll end up with the same code if it's put in the F250 should it be a late 1999.
Without knowing which vintage each is, it's hard to take random guesses at where we should burn your money for you. Just as a start, what are the PCM box codes for either pickup?
Old Nov 3, 2013 | 06:08 PM
wameyer's Avatar
wameyer
What am I looking for behind the hush panel under the steering wheel. I can not look at the PCM yet it just got dark.
Old Nov 3, 2013 | 06:36 PM
cleatus12r's Avatar
cleatus12r
Butt-Head
Old Nov 3, 2013 | 07:45 PM
wameyer's Avatar
wameyer
Well, the f250 does not have the sensor, the f350 does so now I gotta change PCM's back out. Thank you for the help
cobra1379
28
Apr 15, 2017 11:12 PM
SUPERDUTY_08
6.4L Power Stroke Diesel
Aug 28, 2016 08:00 AM
Matt.gullo
Aug 19, 2016 08:39 PM
Twaitesd12
Oct 24, 2014 12:17 PM
sneak
Jan 24, 2006 09:09 PM
