Highboy wheel options?
Old Nov 3, 2013 | 11:59 AM
iggybob44's Avatar
iggybob44
First off, neither of my Highboys( 76 and 77) are particularly original, so im not worried about sticking with stock, or even Ford wheels......As i get older, i like alloy wheels as much as possible since my two highboys are both running 33" tires, and i hate having a sore back for three full days after changing one or more tires. Are the early 2000's Chevy/GMC alloy wheels, or the 94-2002, or 2003-on Dodge 2500/3500 alloys usable? First off, it appears that Dodge are all 8 on 6.5, and the Chevy rims from earlier in this century are that pattern as well. What about backspacing, offset etc? I want wheels of 7.5" or wider, in either 16" or 17", so i can run sizes 285/75/16 or 305/70/16 or 285/70/17's........I really dont want to pay $100-150 per wheel for aftermarket wheels, and i also figure the factory wheels were designed for 8500 GVWR trucks and heavier....Dont get me wrong, ill happily take a good deal on pre 8 on 170, 90's era Ford Alloys, but id like multiple options, thanks!
Old Nov 3, 2013 | 02:01 PM
earthquake68's Avatar
earthquake68
You need to worry about the hub hole more than the offset. I think Ford is the one with the smaller center hole, so it may not be an issue. You also need to get 16" or bigger wheels to clear the brakes. After that, trucks older than (I think) '02 will have the S.A.E. bolt circle. Offsets are wheel by wheel thing. If you happen to find a set on CL, just measure the backspace when you look at them and see if they'll work for you. You fudge the back space a little either way.
Old Nov 3, 2013 | 02:17 PM
iggybob44's Avatar
iggybob44
While i was at it, i measured one of the wheels that had been on the 76, which has the huge Spicer locking hubs on it, and compared it with an extra set of alloy rims that came on the 2003 and newer Dodges, a 17" wheel.......Center holes are the same. the reason i ask is i frequently see the late 90's- 2000's Chevy and Dodge wheels sell fairly cheaply, like a $100 a set........I see lots of Ford wheels here locally in southern Oregon, but 3/4 of those are those goddamned metric 8 on 170 Super Duty wheels.
Old Nov 3, 2013 | 02:29 PM
1972RedNeck's Avatar
1972RedNeck
AS far as these "old" trucks go, dodge and ford take big centers, chevy small.
Old Nov 3, 2013 | 03:30 PM
montana_highboy's Avatar
montana_highboy
35's would play better with the highboys 4.10 gearing....just throwing it out there for public consumption...
With the stock 31's these trucks were wound up tighter than an 8-day clock.... (rpm wise)
Old Nov 3, 2013 | 03:32 PM
Skip1970's Avatar
Skip1970
the only real wheel option is slotted mags, turbines, or stock steel wheels.
Old Nov 3, 2013 | 03:38 PM
montana_highboy
Concur! any other option will never be cool on a dent.
Old Nov 3, 2013 | 06:50 PM
earthquake68
Ok. I knew one of them had smaller hub holes. It's just been forever and I couldn't remember. Thanks for reminding me.
Old Nov 3, 2013 | 08:55 PM
iggybob44's Avatar
iggybob44
well, since neither of my Highboys are near pristine, im only looking at functional......both of them have been modified. both have later model integral power steering, one has a 4bbl 390, the other has a 460. both have 77-79 beds with fuel filler doors, etc, etc. if i someday get a pristine, original truck i will try for originality/vintage appropriate upgrades, but for these trucks i only want what works
Old Nov 3, 2013 | 09:01 PM
montana_highboy
Run stock 6x16 steelies. problem solved.
Old Nov 3, 2013 | 11:51 PM
iggybob44's Avatar
iggybob44
Ive got a couple pairs of stock 16" steel wheels, 6" or so inches wide but that limits my tire options to stuff like 235/85/16, 255/85/16, 245/75/16 or 265/75/16.......i just bought four used 255/85's which are getting hard to find, and all the other sizes l listed were less than 33" height. the 77 has 16x8 alloy wheels and easily fits 285's and 305's with plenty of clearance. The Dodge alloy wheels ive seen are 8" wide, and my old tired back would love to lose the weight of steel wheels
Old Nov 4, 2013 | 12:04 AM
montana_highboy
Alloy's are always a nice upgrade, they cut the rolling mass nearly in half....
235/85/16's are closest to oem spec (31.7")..... it depends what your gearing is.....4.10's need/want a bigger tire to get the motor back up in its power band....so you can cruise at a respectable rpm without winding the motor out.
Old Nov 4, 2013 | 10:53 AM
iggybob44's Avatar
iggybob44
Both trucks have 4.10's, the 76 has a 4bbl 390, and the 77 has a 460, so both have more Hp and torque than stock motors,i.e a 2bbl 360 or a 400M. In my garage, ive got several sets of tires and wheels, including BFG 35x12.50x16.5's on Welds, and a set of Swampers 35x14.50x16.5's on steel wheels( my back hurts just thinking about these)........I had the BFG's mounted on a 72 Highboy that ive since sold, i "adjusted" the front end of the front fenders with a sawzall a little to clear them......
SCFlareside
Jan 20, 2018 09:59 AM
ratfink1111
Large Truck
13
Dec 5, 2017 02:27 AM
BlueOvalLover
Mar 30, 2016 08:29 PM
59flatbedford
Aug 8, 2010 12:11 PM
Bioflamingo
Feb 3, 2009 09:16 AM
