Sponsored by: Real Truck
2004 F-250 with error codes
Old Dec 28, 2023 | 06:24 AM
wildud57's Avatar
wildud57
3rd Gear
Working on an 2004 F-250 super duty and I got 2 codes, P1504 and P1120, I put a new IAC valve on ii, the code came right back, and the TPS code never went away, can someone guide me in the direction i need to go please?
Thanks.
Will
Last edited by wildud57; Dec 28, 2023 at 08:43 AM. Reason: wasn't worded correctly
Old Dec 28, 2023 | 05:04 PM
redford's Avatar
redford
FTE Leadership Emeritus
Welcome to FTE.
I took your post out of the new user thread and started a new thread for you. Your question is too important to be buried in another thread.
Good luck with your repairs!
Old Jan 11, 2024 | 10:46 PM
CathedralCub's Avatar
CathedralCub
FTE Community Team
P1504: Intake air control circuit malfunction
P1120: Throttle position sensor out of range
With the engine stopped and ignition on, I would watch the throttle position with a good scanner or TorqueOBD2 as I slowly pressed the accelerator pedal down and up and see if the telemetry looks sane or not. I bet it will not look sane. If this is the case, replace the TPS and see what happens. We'll also need to know more about your vehicle to help with troubleshooting, such as what engine it has, transmission too, and how many miles it has on it.
Old Jan 16, 2024 | 12:20 PM
wildud57's Avatar
wildud57
3rd Gear
Thank you very much for the reply, i did replace the both the TPS and IAC valve, i got to thinking about a mouse having fun chewing wires, i found several wires chewed on the driver side inner fender, repaired all them and still had issues, i searched more and found a white and green wire chewed at the main engine harness on the left front of the engine, repaired both and wa laa!! my issues are now gone!! Thanks everyone, I hope this may help someone else!
Old Jan 16, 2024 | 03:03 PM
redford's Avatar
redford
Great news!
Old Jan 17, 2024 | 01:45 PM
99powerstrokedF250's Avatar
99powerstrokedF250
Glad to hear when a problem is resolved, even if the resolution wasn't what we expected to see.
Obsdanny17
35
May 25, 2023 05:48 PM
RCates1978
Apr 28, 2021 09:40 PM
Janie Stearns
2004 - 2008 F150
Jan 13, 2015 07:03 PM
hsejkora
Mar 29, 2007 11:12 PM
DanBailey
Jan 31, 2005 06:12 PM
