New here
Old Nov 7, 2013 | 10:31 PM
Ianknightley's Avatar
Ianknightley
Here's a pic of the dizzy ~
Old Nov 7, 2013 | 11:37 PM
orich's Avatar
orich
That looks like a electronic dizzy yes? Dang sure the PO did not replace the oil pump or drive rod or he messed with something. But I'd pull the dizzy and inspect it end to end. Also while you have it in your hand push up on the lower shaft with the cap off and see what's happening to make it run bad..orich
Old Nov 7, 2013 | 11:47 PM
Ianknightley
Okay will do. I'm pretty sure it's not electric, how would I tell..? Sorry, I'm not the best on distributors.
Old Nov 8, 2013 | 08:29 AM
orich's Avatar
orich
If it's got points it's manual, If has a 2 wires coming out that connects with a large plug that leads to the Box off to the side of the inner fender wall then it electronic from a 76 model...orich
Old Nov 8, 2013 | 09:22 AM
Ianknightley
Ok thank you, il check it out today after work
Matt Rogers
Jul 21, 2018 01:20 PM
roguewave
Mar 28, 2018 10:23 AM
Yaesu
22
Nov 28, 2016 02:47 PM
hharris8
67
Aug 16, 2016 05:24 PM
QuangBroncoII
Bronco II
Feb 20, 2004 05:49 PM
