signs new belt needed?
i snapped this picture today.
i can't see any cracks or other signs the belt is bad. a short while back when cleaning up the engine bay, i took a scotch brite pad, and with the engine running, lightly "scrubbed" the buildup off this pulley/tensioner. i comes back, and i was wondering what causes this. is it normal, or does it mean the belt is worn, or the pulley is not turning free enough? any ideas.
Kevin, how many fingers do you have? lol. Don't think I would try that. Anyway, I changed my belt at 100,000 miles. It still looked good but I changed it and keep the old belt as a spare. I have seen marks like that on pulleys before, but don't know how or why they are there.
If you think it needs changing, change it.
The rule I use is 4 years regardless of mileage. Belts and hoses change at the same time. Tires over 3 years old that are weather checked will fail you sooner than later while towing, especially in the heat of summer. I doubt the tracking means anything other than " there is rubber on the pulley", but stick to the 4 year rule and you'll rarely break down for belts and hoses.
Is it just on the top pulley? or is it on the water pump pulley as well? any oil leaks or anything that migh be building up the stuff on the pulley? oil leaks, dust and dirt, etc. Just wondering as teh the pattern is a little funky and not a straight line across the pulley.
Also looking at the picture again, to you know if the tension is even across the pulley? Maybe it is tilted back some putting more of the pressure on the side closer to the engine.
i'll probably do both as well. where's the best place for these. i seem to recall others having problems with advance auto or autozone belts. are motorcraft parts the best?
