Bronco II Ford Bronco II
no power???
Old Nov 1, 2013 | 07:11 PM
Tom1.0's Avatar
Tom1.0
no power???
Hi all,
My 1987 2.9 v-6 , has a crazy problem.
this is a rebuilt engine,all normal stuff replaced,
when the temp outside is above 70F it has no power, lucky to get it to run on the flat , must keep RPM'S above 2500 to 3000. so only getting to 3rd gear ( manual 5 speed overdrive)
Now when temp outside is 70F or below it runs pretty normal.
But in order to drive it , i Have the timimng set at 24 BTDC,and it should really be at 14 BTDC.
Have replaced all sensors with used ones from another engine.Their condition unknown, ( used,from junk yard)
Cant afford to just throw out $30 at every sensor to troubleshoot which one is bad, thats if it is even a sensor,,
Fuel pressure,tested,new fuel filter,air cleaner,plugs,wires,cap,rotor.
Any and all help is welcome.
Thanks...
Tom
this post can be removed,,,
Last edited by Tom1.0; Nov 1, 2013 at 07:22 PM. Reason: oopps, wrong section, reposted in Ranger section
Tom1.0
1983 - 2012 Ranger & B-Series
16
Nov 10, 2013 08:29 AM
shanes66charger
Nov 3, 2013 08:18 AM
Hardcase_Ford
Bronco II
Feb 18, 2011 03:00 PM
welda
Bronco II
Aug 31, 2009 07:16 PM
developer
Feb 25, 2003 01:40 PM
