1961 2wd performance disk brake conversion
Old Nov 1, 2013 | 02:24 PM
gear_grinder's Avatar
gear_grinder
Hi,
I'm trying to get an idea on what are the largest/most track oriented brakes that will fit under the stock 15" wheels. I've been thinking about swapping a newer crown vic front subframe under the front of the truck (IFS and big brakes), but i would probably need 17" wheels from the crown vic as well.
I've been looking at taking some of the parts from the speedway motors kit (most the caliper brackets) and then piecing together the rest myself. Probably would use some drilled and slotted rotors, hawk pads, and a pair of these (http://www.summitracing.com/parts/wi...7-rd/overview/) for a bolt-together setup using the caliper brackets sold by speedway
now the other issue i'm thinking of could be possible axle wrap under hard braking (with some good tires obviously) causing additional camber and possibly leading to death wobble, which could be very bad at higher speeds
Old Nov 1, 2013 | 09:56 PM
garbz2's Avatar
garbz2
No disk brake kit will fit under the stock innie rims.
The rims are old style in how they are made and not safety bead type.
However you can get up to 18s for Stockton wheel with the modern hoops and the innie cap stamping. Look at the Henry.
Garbz
Old Nov 2, 2013 | 11:03 AM
gear_grinder
Garbz
I'm guessing English is not your first language?
"no disk brake kit will fit under the stock innie rims" lulz wut? what is an "innie" rim? and why would speedway motors sell the kit to fit stock truck components 59-64 or w/e the year range is....
"The rims are old style in how they are made and not safety bead type" sounds like a bad English translation, they are a single sheet standard style steel wheel, nothing special or unusual about them compared to really any other steel wheel.
"However you can get up to 18s for Stockton wheel with the modern hoops and the innie cap stamping. Look at the Henry."
okay, a couple problems with this one
stockton?
innie cap stamping?
wtf is "the Henry" lol?
Old Nov 2, 2013 | 11:25 AM
6t6merc's Avatar
6t6merc
Garbz meant this:
Stockton Wheel - Products Smoothie - GM Rally - Milner - Henry
I think you might have been just slightly rude to him.
Eric
Old Nov 2, 2013 | 12:43 PM
garbz2's Avatar
garbz2
Yep, If you have no idea what i posted then you should stick to playing with Honda's.
Garbz
Old Nov 2, 2013 | 02:55 PM
Conserv's Avatar
Conserv
If you're asking for help, it pays to be nice. I'm not even a truck guy, but I've spent a little time on this forum and what garbz2 said made sense to me.
Steve
Old Nov 4, 2013 | 08:23 PM
theastronaut's Avatar
theastronaut
Anything that fits under a 15" wheel probably won't be "track oriented" The rotors will be too small. Larger rotors = more leverage from the calipers. You might can find smaller brakes that stop well, but they'll have to work harder so they overheat and fade sooner. You'll probably have more tire options (in truck appropriate sizes) for 18" wheels, and I bet they'd be cheaper too. Most 15" sticky tires are going to have a very small diameter.
Just picked these up for my '66 C10 that will be run at open track days, autocrossed, and flogged at amateur/practice drift events. They're 2009 up CTS-V/Brembo 6 piston calipers that'll go on 14.5" rotors. They're around $510 shipped on Amazon so they're not terribly expensive either, only ~$180 more for the pair than the D52's you posted. Might be worth looking into if you're willing to go with larger wheels. They're built to stop a 556hp 4200 pound sedan (fastest production sedan around Nurburgring), so they'll do even better on a lighter truck.
Old Nov 4, 2013 | 08:54 PM
gear_grinder
I agree with the larger rotor, but for the look i'm going to keep with the truck i cant go with larger then 15" wheels. Fade resistance is my key issue (slowing from very high speeds), but within the confines of a 15" wheel makes it a bit of an engineering challenge.
The 15" wheel basically limits me to the 11.7" rotors, i dont think much else will fit under a 15" without alot of extra work. After some research, i'm planning on using d/s f150 rotors, wilwood or howe's racing two piston sliders that are bolt-on replacements for the GM d52 that are used in most bolt on kits. The larger aluminum calipers will disperse more heat (by both the greater amount of fluid contained within them and their physical size) and provide superior braking force. Hawk HP plus pads will most likely be used for their superior fade resistance probably with DOT 5 fluid in the system. That's about it for the "off-the-shelf" parts...
Some dedicated and hidden duct work and maybe increasing the reservior of fluid will help reduce the chance of fade and extreme fluid temperatures.
Old Nov 4, 2013 | 09:09 PM
theastronaut
If you're sticking with 15" wheels, use newer steelies that are designed for disc brakes- the inner bell is larger diameter. Not sure about Ford, but GM had 12" rotors inside 15" rims from the factory starting around 1971. Might could swap your Ford centers into GM (or other 15") barrels if they have more clearance. Have you looked into Aero Racing wheels to see what the ID of their wheels are? Might be larger than stock. Wide-five dirt track wheels/brakes might be an option too, but they won't keep the stock-wheel look. Just throwing ideas out.
Old Nov 4, 2013 | 09:14 PM
gear_grinder
good ideas, but i'm trying to keep the truck looking "stock" from the outside as much as possible. If i need a 15" wheel with more clearance i'm thinking about ordering some wheel vintiques 15x7 12 series (of course i'll have to do some actual measurements and research into the inner diameter of the barrel to see if there is a gain in size). I'm planning on using some 15x10 12 series in the rear anyway for some ~12" wide rear tires
Old Nov 4, 2013 | 10:15 PM
Shadowrider123's Avatar
Shadowrider123
F100's could have had 16in steel wheels as well.
Are you sticking with the solid front axle?
You are talking about a lot of brakes for a truck that does not handle very well.
Old Nov 4, 2013 | 10:19 PM
gear_grinder
i'm still debating on keeping the straight axle, but all it needs to do is go straight-ish. I basically would just need the fade resistance to safely slow from high speeds.
If i do keep the straight axle I'll be adding alot of extra negative caster along with some anti-wrap devices. I may also try and play around with a rack and pinion steering...
Becky_is_a_66
16
Sep 29, 2014 09:03 PM
spongecop
Jan 24, 2013 01:48 PM
Ekkehard
2004 - 2008 F150
Oct 12, 2012 10:10 PM
racsan
Aftermarket Products
Oct 5, 2011 02:50 PM
fulltimehiboy
Jan 14, 2007 07:12 AM
